Re: Scored a Nice 16" Parabolic Reflector. HID or Short Arc? Test Beamshots w/ HID.
Thanks again for the good input. I agree about skin damage risk from UV being very low; I am more worried about eye damage from UV, though. Good operational safety - never pointing it at anybody - is certainly my intent. The accidental exposure risk is low simply because the probability of exposure is low, with responsible use. Any accidental exposure would likely be very brief, as well.
What about eye damage from UV? Might that occur faster then one could sense pain from the visible light? (EDIT: Answer = Yes, absolutely this can happen!)
I would like to have a better understanding of the level of UV emitted. For example, is it foolish to illuminate a white wall from 50' for beamshots for 15 minutes, without eye protection? I really don't think so. But, I also don't want to use the 'Do my eyes hurt yet?' method any more than I have to!oo:
I wear polycarbonate safety glasses even when testing the 35W HID in my shop, with indirect viewing. I know those lamps are supposed to be UV filtered, but I also know the factory HID lamps in my car have severely crazed/fogged the INSIDE of the plastic housing's front lenses over 100k miles, so there is still some UV. (Saab 92-x Aero if it matters).
I realize this is a very challenging issue that we are unlikely to answer adequately. But in this particular forum, I think it merits some effort to try to understand. I feel that, if we are going to discuss building lights with a lamps that emits 'dangerous, intense UV radiation', then we should try to devote a respectable amount of effort to discussing safety aspects, too. If others hadn't done the same in their short arc threads, I might have read them without realizing there was a significant UV hazard to worry about. Also bulb explosion. Let me offer a sincere thanks to others who have included such warnings!
<<< In case anybody has read this far and not figured it out, don't build something like this just because I am trying to - I barely know what I am doing!
I've decided while writing this that I must improve the perimeter light baffle, so there is less rearward light 'splash' from light reflecting off the back surface of the lens in the narrow perimeter air gap. You can see how intense this small portion of reflected light looks even with the 35W HID, in the repeat-picture, below. The baffle is not installed, so the back-reflection is clearly visible.
If 90% of visible light is transmitted through the glass (optimistic), that reflection is still up to 10% beam intensity. With the new MSR lamp: 10% of 'dangerously intense UV' will still be 'too much UV', if I am remembering my higher math correctly.
I am a very safety conscious person. I worked for a public agency with an aggressive safety officer in the office next door. It was drilled into me for 34 years. So this may sound counter to my past experiences. You're never going to want to point the light at anyone so UV emissions should not really matter. And a momentary "hit" at some distance is not going to do any damage. Eye damage will occur before any burn damage. I remember someone foolishly putting their hand in front of (2" away from the window) Larry Black's VSS-3 at a get-together. He did, indeed get a slight burn on his hand. There is no UV spec given for the lamps you're considering? But again, not sure I'd concern myself assuming you're aggressive in safety procedures when using the light.
