Hi
I need some help finding a light i can use for scouting camps. Im a scoutleader for 6-8 years kids. For that i want a light close to a SAR light, just in case that we have to search in the dark. We suddenly dont hope that will happend. But just for insurance i want a good light for searching and scouting use.
For now i have a ledlenser t7m. Im actually quite happy for that light i gives me. But!
If i could get a light, lets say..
-Twice or more powerfull in lumen.
-Distance aprox the same. I think the distance of t7m is okay. The flood is 70/30 for me.
-Runtime is very important for me, im not for rechargeable lights. Lights can not be used while it recharge, i would rather carry 2 sets of batteries in my pocket so the ight can run all night.
-Price range: 100-200$
What light do you think i should look for?
Thank you
I'm an ASM in our scout troop, and a member of our local CERT team.
When we did a training for a wooded area SAR, it was my partner who discovered the manikin they threw into the ravine. I realized that if it were a night SAR, we would never have found it with any of my lights. I came here for a recommendation for a wooded area SAR light. Your T7M is better than the lights I had at the time, but it is still terrible, mainly because of the power supply. I opted for a Thrunite TN30. It is a triple LED that takes 3 18650 LiIon batteries. I bought 6 batteries so I could run the light near full power all night.
Let's talk about batteries and how they work.
Alkalines, Rechargeable NiMH, and rechargeable LiIon.
LED output is very voltage sensitive. I can't write a thesis on the subject because I don't know it well enough, but I think I can get by. As battery voltage drops, so does the LED output. As the LED output drops, its amperage demand on the battery drops. As the amperage demand on the battery drops, the longer it takes for the battery to use up its total capacity.
To obtain an output double of what you already have (400 lumens), you will have to supply about 2000 to 2250 milli-amperes @ 3+ volts to get near 800 lumens.
Alakline cells are terrible for high output lights. Your little AAA batteries are pushed to their max at 400 lumens. And they can't maintain that level of output for long. My guess is that at 15-20 minutes they are at about 50% output. Alkalines drop their voltage rapidly at first, and then linger on for a while (depending upon the demand) and with LEDs at a low output level.
If you want to run alkalines, get a three D cell light that outputs no more than 400 lumens. With that you'll get through the whole night even though you may need to swap out the cells near day-break. If you get a 1000 lumen light you will certainly need to swap out the batteries before the night is through.
The long run times that others have posted about maglites are true, but for most of the hours, the light is too dim to be use-able for SAR. The demands placed on the battery to get 800-1000 lumens cause them to drop voltage rapidly so that the output also drops. It will then run at a low output for many hours, but again the low output may not be what you are looking for.
On the other hand, rechargeable NiMH and LiIon batteries of similar capacities have a straighter line of discharge than alkalines. They will hold their voltages until they are nearly depleted. You'll get shorter run-times, but at relatively higher levels of output. In a SAR situation, if you are looking for higher output, and are willing to swap out batteries, you'll get much better service from rechargeables.
Now if we discuss battery capacities, a single AA cell is equal to about 3-4 AAA cells. and a single 18650 LiIon is equal to about 3-4 AA cells. Therefore a single 18650 LiIon cell is equal to 9-12 AAA cells. FYI, your 18V LiIon powered drill has 5-10 18650 cells in it, depending upon the size and capacity of the battery pack.
Either NiMH or 18650 LiIon cells can be charged, topped off before the trip, and spares can be charged while the light is in use (with a car USB port if necessary).
If you would like to check out how different batteries and chemistries perform under varying loads check out HKJ's site @
https://lygte-info.dk/review/batteries2012/CommonAAcomparator.php
When I go camping with the scouts, I bring more lights than I personally need, but I bring extra lights to share with others in-case a kid goes missing.
I use an 18650 headlamp, one that has a mix of flood and throw.
I also have a couple Convoy S2+ lights.
http://www.candlepowerforums.com/vb/showthread.php?415313-Convoy-S2-measurements-(7135*8-3B)
One with the biscotti software that gives a particularly low low, that I use for a tent light with a diffuser, but it can be used for short distance SAR work. Better than most lights others carry.
I also pack a couple, maybe three Convoy C8 lights, with holsters. These are specifically give away, loaners.
My grandson is always with me, and he prefers, more than any others the Home Depot Defiant triple led lights that run on 3C cells. I made adapters for them to run on a single 18650 battery. They light up a 70-100 foot path out to 100-150 feet. He brings one, and I usually bring a spare.
The best part of all of this is that each of these lights can be had for less than $15.
Batteries that used to cost $18 each are now obtainable for about $6-8 each.
I think that a four port charger can be had for about $20.
