fyrstormer
Banned
Bah. I've carried mine almost every day since January 2011; that way it's in my pocket, where I know it's safe.I used and carried it every day for about a month after I got it. I still carry it every now and then, but now I like to keep it I my pelican case where I know its safe. .
It's the "Mini Blunt Bezel" for the RRT-0. It needs some sanding around the cut edges to make it pocket-friendly, but it's a good add-on so I can tell when I've set the light down without shutting it off.Where did you get that bezel for your TC-R2???
I use the red polish that comes with the Dremel polishing kit. I use a lighter to melt a bit of the polish, then I smear it on a heavy-duty paper towel, then I twist the paper towel around the light. It works like a charm and it preserves the circumferential machining lines on lights that weren't mirror-polished from the factory. (if I wanted to get rid of the machining lines, first I would sand along the length of the light, then sand in an orbital pattern, then polish circumferentially.)What did you use to polish your TCR2? My car keys haven't been kind to the finish on mine and I wouldn't mind spiffying it up a bit.
