Some advice please
Undertoker
uk
Hi guys
i am trying to find the most powerful flashlight that hasn't got active fan cooling (because the noise I don't want)
At the moment I use an Imalent ms06 that I've had for a while
I am tempted by an ms18 but the noise is like a jet engine
any suggestions
thank you in advance guys , I appreciate your taking the time to reply
Seattle, WA
Does the fan run based on the mode, or the actual temperature? I think if you were to dial back the output you could avoid the noise, and still have one of the brightest lights. If you buy a different light you're just moving the hard limit back due to the passive cooling.
Undertoker
uk
ive read about the imalent MS12Mini that currently in the testign phase and that looks promising, i dotn think is has fans by the look fo the pictures and is 70k lumens, so i will be lookign out for that i think to find out more when they release it
kerneldrop
South
Hi guys
What's your budget?
Are you wanting a light that advertises 70,000 lumens for 15 seconds from laboratory calculations, or a light that is guaranteed 1600 out the front lumens and will last forever?
