Spy 007 Pics
orb
UK
Rob, this is a family type place and your Spy is like naked!:eek: ......... no O-Rings :p Do you like the switch better without the O-Rings?
Oh and :kewlpics:
:wave: Kenster, For now yes I prefer naked. Added a couple of ice blue locators to the slots provided so I can keep an eye on her tonight.
Edwood
SoCal
I love the "packaging" that the SPY 007 comes in. A Pelican 1010 case. :) Now if we can get some custom foam inserts cut with holes for spare 123 batteries too, now that would be perfect. ;)
I would've posted pics earlier, but CPF has been having problems a lot today. I just gave up and came back later.
Here some pics of mine. I focused more on close ups and beamshots, since people have already posted plenty of full body shots.
Machining is immaculate. Only thing that is off, is the teflon washer is a little too big and sticks out.
Oh, and the lanyard hole is so tiny that only the smallest cell phone strap type lanyards will work. You'll have to use some kind of monofilament woven into paracord or something like that if you want a fancier paracord type lanyard.
-Ed
Scottiver
California
Very cool pics Edwood. I especially like the one with the Orb-Spy-PD. I'm going to be able to complete that trio myself soon I hope. :thumbsup:
N162E
Warren, MI
+1 I have tried but never been very good at shooting shiny, small items. What did you use for lighting? Are your shots taken in a light tent? What camera/lens did you use? Thanks!!:grin2:
souptree
The photos in this thread are GORGEOUS!! Great job, guys! :thumbsup:
Edwood
SoCal
Close up shots were shot with my Pentax *ist DS with 35mm f/2 lens and close up filter. (I really need a real macro lens).
Last two shots, including the beamshot were shot with my Nikon D80 with 18-200mm VR lens.
Lighting used was an Ott-lite lamp, special equipment was two pieces of white illustration cardboard. :D
-Ed
tino_ale
Paris, France
Hi guys!
Here a just a couple of pics I have shot. Lighting is natural, quite neutral and cool.
What you are looking at is an industrial chunk of solid titanium :faint:
Serial #0202 and the rail
Tailstanding will be a piece of cake
Wow the guy wasn't kidding when he said the emitter would be perfectly centered :party:
Machining is as smooth as it can get, yet is not buffed out so it keeps 100% of it "crisp" look
Absolutely no trace of any foreign stuff on the reflector or glass, no fingerprint, no visible dust
Now, my few thoughts :
- The feel of the wheel is superb. It plays a huge role in the fact that you can't put this flashlight down. You just keep it in your hand, and clic, clic, clic... it's so addictive as it has already been pointed out. But it really is! The response is firm and the clic idealy audible. Less would not be as good. The sound and feel are just perfect, you've got a clear feedback of the level change.
- It is realatively heavy but totally acceptable IMO for a 2 cells torch. It also gives a solid feel that what you have in hand is built to last.
- the tailcap is a great piece of design. The locking mechanism seems undestructable. Again, closing the tailcap really gives a firm and positive feedback with a clear "clic". You won't be asking yourself it the door is properly closed or not. Spring tension seems very good too.
I don't want to go on with a list of everything that is fine and refined about the Spy, a lot has been said already. It is my first SPY and will be the last flashlight of all I've got that I will let go if I'm forced to. This 007 is a keeper and I really doubt any of them will show in B/S/T unless in a case involving financial issues for the seller. I could be wrong, but heck I would be extremely surprised if someone didn't like his SPY.
Now, what could be improved. Well, not much, and I have to dig in the smallest details to find any idea of improvement.
- although there is zero axial play in the button, when it is on any of the 6 levels, it has a small rotary play of a few degrees. I think (I am not positive) that I would prefer no play at all once it has reached a level. That said, as it is you can't have the light flicker between two levels even if you try to turn the button very slowly, and I'm not sure this would still be the case. What I'm saying here could be BS and the more I think about it the more I believe there is no other way to make the flicker impossible.
- the teflon ring would be less visible if it had a smaller OD
And... that's all I have been able to find so far. I even feel ridiculous to post my poor findings :crazy:
Cheers and long life to the 007. I am not aware of any other custom flashlight that is as close to perfection as this one.
tino_ale
Paris, France
AND... Let's see how it looks with tritium vials (not potter, just tryin')
Not too bad eventhgou asymetrical...
A funny idea if there's any sailor around here : a green vial on the right, a red on the left :)
chipwillis
Minnesota
This is the best pictures that I can do. My little guy and my SPY007. He thinks its his, now I might have to figure out a way to get another.
Data
PA, USA
. . . That said, as it is you can't have the light flicker between two levels even if you try to turn the button very slowly, and I'm not sure this would still be the case. What I'm saying here could be BS and the more I think about it the more I believe there is no other way to make the flicker impossible . . .
Let me see, how can I explain . . . the STFu is a microprocessor (uP)controlled converter board. It's computer is filled with 8K of logic that I wrote and compiled from my C code. The switch state is read by the uP. It either reads that the switch tumbler is at a location or it reads that it is in between two locations. This is because it is a break before make type of switch.
The uP logic looks at that switch state every so many micro seconds and then decides what to have the DC to DC voltage converter send to the LED. If it sees that the switch has just arrived at one of the seven locations it takes action to control the LED. If it sees that the switch is still on a previous state or is in an open circuit state it goes about performing other tasks. Typically it is always busy with reading the current going to the LED and adjusting the output to maintain a constant current target. A target that is specified by the user.
That is part of what is going on inside the SPY controller board. It would take me a large text to even overview all that is in there. It took Wayne a long time to design the converter board and start the code. After that, he handed it to me I spent 1.5 man years perfecting it and that spanned several hardware iterations from Wayne. I am very proud of the STFu and so is Wayne. It is very advanced and on par with the very best in the industry.
So to sum this up, the switch can never be put in a static state that will cause flicker in the output because it would require transitioning through three states and back again.
Cheers
Dave
jdriller
New York
. . After that, he handed it to me I spent 1.5 man years perfecting it and that spanned several hardware iterations from Wayne. I am very proud of the STFu and so is Wayne. It is very advanced and on par with the very best in the industry.
Cheers
Dave
1.5 man years ...... that is "A LONG TIME" to you and me!
Thujone
Nebraska
awesome pics, flashlight porn at its best.
how about some more "action" or in-hand shots?
I concur.
Dad, I demand you get some pics with Casey... I am sure you remember her. Perhaps her friends would join in..
Thujone
Nebraska
LOL, you're just gonna have to get your a$% back down here and join me in the festivities. I'm sure she'd like to see your Spy. :D
Can you imagine a shot with her and two of her friends with yours mine and griff's 007 posing like charlies angels... :naughty:
