thermal guy
I remember the discussion on using 3.7 cells in the A2 but couldn't remember where it left off thanks. And god that's a beautiful A2 black and 4 sides! There was a time if you had one of them you were a flashlight god.
https://www.candlepowerforums.com/v...ad-s-customs&p=5032366&viewfull=1#post5032366I remember the discussion on using 3.7 cells in the A2 but couldn't remember where
I acquired an A2 not long ago and also LF's LED upgrade. Did try 2x3.7Vs briefly but then stopped (I'd say less than 1 minute cumulative). The stock LEDs still light up but hope I didn't destroy them (and the ring)...For my A2 I have some problem with a ring and I buy Koala ring and HO-A2 from Lumenfactory
I never use 3.7 V, Because I don't want to destroy a ring
Now I try to clean the original ring and work normally I Keep original ring and incan for spare part
Won't fit and won't work.IF it fits, any reason NOT to use a 16650?
Forgot about that thread AND the regulation/circuit/electronics being the issue. Thanks man!
Too bad I have discovered the A2 after parts and support are shot .... I take it out to play with but am afraid to hurt it or wear something out....
Z62 is the gas pedal natural?
Agree that the tailcap switch seems to be the weakest link. But lately it's not easy to obtain one even on eB...I In particular, apart from normal consumption of lamps (although the soft-start circuitry helps these last much longer than more typical incandescents) , it is the switch which is the part most likely to eventually fail. So, try to get a few of those if you can, and you should be good
Just for giggles, I have an L1 and an L2 (well, my wife absconded with them.) Same?
Bought a used A2L tailcap a while ago for testing. Does fit onto the A2 without problem (except for the dot indicator not lining up with the body nub), high/low mode all normal..Yazkaz, are you certain? I mean first hand or close? I will find one just in case if you know this! Thx
