RobertMM
i have a ton of lights that only use primaries as voltage is to high for rechargables.
looking to get a few for the 1t
from what im reading the k2s from SF and efest imr's seem to be mentioned alot and have seemed to be reliable in this light. please stear me otherwise if not.
another question, has anyone tried the tailstand shroud on this model? it seems it would be ok to use on the tacticion as the whole tailcap doesnt move but i was curious as for the gas pedal switch.
Safest for the EDCL1T would be the K2 which are not the best in terms of runtime but would be closest to the voltage of a primary CR123. Mine work great and charge to 3.4volts when full, with approximately 30minutes runtime in high.
The true 700+mAh cells like the Fenix, Vapcell and Klarus 16340s will give the best runtime of around 40min + on high but are officially unsupported by Surefire. Some members use them though. No need for IMR s on this light as the current draw is not high enough to warrant that chemistry. Some members may prefer IMRs because of no low voltage cutoff, just like the K2 energy LiFePo4 cells.
