js
OK. I'm at home on the dial up and I have to get back to SF M6-R orders work, so I'm not going to go back over all the posts in this thread. Not today anyway.
But, for what it's worth, I just did a runtime test of the New Titanium 123's in my M6 with MN21 HOLA installed.
I got 15 min 45 sec and then one or more of the batteries thermally shut down. I waited for a bit to let them cool, and then continued the test, getting another 8 minutes until obvious dimming. I could have gotten more, but it would have been increasingly dim and I believe I picked the proper cutoff point at obvious and increasing dimming.
The batteries were all equally hot--about 150 F or a bit less, going by the standard pain tests. (If you can't hold onto it for any length of time at all, it is >160F. If you can just hold it for a second it is around 160F. And if you can hold it for a few to several seconds it is 150-140 F. Etc.
Not very accurate, maybe, but you get the idea. I could hold these for a few seconds before chickening out.
I have done this sort of test with SF 123's before, and got similar results, except that thermal shutoff occured at 10 minutes, IIRC. And the cells were just as hot as these bad boys. Maybe even hotter.
OK. Hope that helped.
