JimmyM
The MOSFET I like in place of the 1324 or 2804 if voltage won't exceed 30V is the IRLR7843. I'm using it in testing my soft starter and am using it as a MOSFET switch in My 2C ROP-Hi.
OK !
6x A123 - IRC65
Mag Switch - 20.9V Open Circuit
19.10VBulb @ 6.44A
FET Switch and TailFix - 19.97V Open Circuit
19.28VBulb @ 7.10A
With slightly more used cells still get higher VBulb and higher Amps.
6x A123 - 64458
0 Min . . . . 21.1V O/C . 19.5VBulb @ 11.6A (226W)
3.5 Min . . .20.0V O/C . 18.6VBulb @ 10.4A (193W)
7.0 Min . . .19.7V O/C . 18.3VBulb @ 10.2A (187W)
10.5 Min . . 18.9V O/C . 17.3VBulb @ 9.6A (166W)
~11.5 Min cutoff @ 15V
Slow dimming and drop -off.
Recharge 2.8Ah in 22min
5x E-Moli - 64458
0 Min . . . . 20.5V O/C . 18.7VBulb @ 10.6A (198W)
3.5 Min . . .19.7V O/C . 17.9VBulb @ 9.8A (175W)
7.0 Min . . .19.3V O/C . 17.6VBulb @ 9.6A (169W)
13.3 Min . . 17.5V O/C . 15.0VBulb @ 8.6A (129W)
~13.3 Min cutoff @ 15V
Very flat middle section !
Precipitous - Almost vertical drop-off at the end - very rapid dimming to possible cell damage ?
Interesting !
Pete
When you say rested, how much do your emoli drop.
I forgot to mention the other night ran 64458 on 6 emoli. All around 3.78V; the resting "pack" so to speak read 22.48V.....
and I got 20.4V on the pins :devil:
The lamp realy shone there..........
But I forgot that the cells were realy depleated so the light soon faded of in my exitement.
64458 is great with 5 fresh emoli. no way getting 20.4V to the pins...
With 6 fresh will have to find a way to harness the 25.2V start up potential. I'm sure that would drop, and wouldent find its way to the pins, but i'm sure it will flash the 458 but not for a little while.
Had planned to fire up the 655 and 657 on 5 6 emoli and see what V made it to the pins, and then work out what I need to hook up 7 emoli together.
No worries on the 64657's, my pleasure for all the help you have been OH you dont have to one of them instantly BTW. Might aswelll clock up a few miles on it first. I'd be interested to see how the 657 likes the overdrive, as it has between 200~300 hours verses the ~50 I think the 64655 has, but either way Its going to be a very long mag for 7 emoli
Oh BTW got 5 emoli straight into my 7C the other night, no modding needed, Not sure why I couldn't before. Still it is so nice with 5 in ... a nice platform for the 458 and the other lamps Pete that has already tried on 5 emoli. I will have to get round to digging out the IRC's
Now my 6D will become my 6 and 7 emoli platform for the moment.
458 thows so so well with FM 3" reflector.
Just reading back to your 5 emoli on the 458 post Jim, and maybee the NTC would help out with the 6 emoli on the 458
Here is one I'd add.
G4 pin 35w 6v overdriven to 14.2v >8,000 lumens
https://www.candlepowerforums.com/threads/180177
I'm really trying to bring some rigor into claims like this, and hated to see this claim made this way.
Maybe I'll pick up a 6V 35W bulb at my local hardware store and make a claim that it is a 20,000 Lumen bulb! Unless there is REAL WORLD verification of lumens, this is just going to confuse people. On a preliminary basis, count me as a skeptic.
JJ, read my post #13 in your other thread that you started. No point in double posting....and don't take any of my comments personally. I'm just as guilty at wanting the Hotrater to be accurate...but I had no idea until this week how meaningless it has always been. AWR confirms this in conversations with me.
JJ. Chill out my friend. We are not going to convince each other tonight. Let's let it rest for now. Just please stop assuming any of this has something to do with making $$$ off of bulbs or drivers. For me it has to do with bringing some science into bulb performance.
So is the 657 too powerfull?
When you say bubbled up, what reflector were you using? FM 2" deep reflector, sounds expensive
Where did you have the insulation placed?
Did you have one of your funky lenses on it aswell?
I'm guessing a 5 min continuous run is out of the question with these high Watt lamps, mind you I haven't run anything higher than a 64623 for ~ 10 mins in the same light, and that was hot as hell, but I was walking outside at the time.
Yes I am a equal oppertunity destoryer. Carley and FM one each. This one was a 2" deep.
