neutralwhite
will the UI change you think on these new releases ?
thanks.
thanks.
No.will the UI change you think on these new releases ?
thanks.
It can take a bit to get used the UI, but once you get the hang of it, it's quick and easy to get just right amount of light. And best of all, their electronics are extremely efficient, giving you great runtimes from high power to very low power output.In for my first Zebra. 519 without paying for modding?! I need to go study the programming to get ready = )
The only change that could be made is to degrade it. It's not changing.
I like the idea with on/off memory in one of the mode groupslol, i'm clearly a ZL fanboy, but even i think the UI has a lot of room for improvement.
they could make programming easier, for one thing. fully programming a zebralight is several hundred clicks, which is honestly fuked. and if you know what you like, you can only reproduce it with relative counting by either counting up from the floor or counting down from the ceil. relative counting sucks because you have to waste time getting to the floor or ceil first.
they should make an 'expert mode' that works like this when you enter it: it steps through each of the six (sub) modes, and when you're on that mode, you click 1-12 times (because 12 brightness levels exist). i.e. you input in absolute terms the brightness for that mode. example for G6 or G7:
this, to me, would be far less frustrating. i'm someone who has programed tons of them not just for me but for family and friends, so i already have my preferred brightness settings in my notes for each model.
- it flashes once to indicate mode 1 ('H1' in legacy ZL speak): you click three times to indicate you want brightness level 3 (of 12, where 12 is max brightness). then, after a timeout of no input for 2s, it flashes rapidly a few times.
- after a pause, it flashes twice to indicate mode 2 (H2). you click 5 times to program brightness level 5/12. you wait a couple seconds for timeout, and it rapidly flashes.
- after a pause, it flashes three times to indicate mode 3 (M1). ...you get the idea
another improvement they could make is a setting to enable or disable submode memory. i.e. is M1 vs M2 remembered when you go back to M, or does M1 come on first every time?
This is an exaggeration, as it does not take more than two hundred presses. I estimate it takes about eighty to fully program every mode and submode, but assuming all modes start at brightest level and are programmed for dimmest level (which would never happen and be pretty silly), it would take no more than 120 presses.
This guy Zebralightsplease don't assume that i exaggerate when i write a detailed post like that, lol. i rarely exaggerate.
also, please provide a calculation to support your claim.
sc64w hi example settings:
g6:
H: 2, 4 (brightness levels 2 and 4 of 12 – i use H as low)
M: 6, 7
L: 9, 11 (i use L as high)
g7:
H: 1, 4
M: 6, 7
L: 9, 12
12*12 + 2*(11+10+7+6+8+9+6) + 12*12 + (1+3+5+6+3+1+6) + (0+3+5+6+3+0+6)
- 12 submodes (g6&g7), 12 clicks each to enter programming mode.. uh oh, at 144 clicks, you can see it's already not looking for your estimate at statement 1 of execution
- 12*12
- + initialization pass: move all sublevels to floor or ceil for relative counting (then multiplied by 2 (g6&g7)):
- H1 and H2 to floor (i use H as low): 11 (H1: 12→1) + 10 (H2: 11→1)
- M1,M2 to floor: 7 + 6
- L1,L2 to ceil (use L as high): 8 + 9
- + 6 clicks to turn the light off (one click each time)
- + programming pass: in practice, i do the actual level setting in another pass as it's easier for me to keep my train of thought and count that way. but you may subtract 12*12 from the result if you think this inefficiency for the sake of sanity is unfair exaggeration.
- 12*12 to again enter programming mode to finally set the levels
- g6:
- H: 1 + 3
- M: 5 + 6
- L: 3 + 1
- + 6 for off
- g7:
- H: 0 + 3
- M: 5 + 6
- L: 3 + 0
- + 6 for off
= 450 clicks by this estimation
(or over 300 clicks if you demand that i exert my brain more than i care to during programming and not do multiple passes)
in practice it is even more clicks because i do extra clicks when i get to floor or ceil to confirm i'm really there. i keep spamming the button until the brightness doesn't change, and that's how i know.
There are 3 submodes and 3 modes for each group, so even if you're moving goal posts and talking about programming all three groups and not just one, that's 9 submodes maximum and 9 modes maximum, and it would go over 200 presses if you wanted to program all three mode groups immediately. But I think your complaint is unreasonable because you're never using all three mode groups, you're only using one or two at the very most, and once you switch to a mode group, you're not switching back and forth between mode groups constantly. There are 12 light levels. Undoubtedly you're using between one and three of them no matter how you program the groups.12 submodes
they should make an 'expert programming mode' that works like this
There are 3 submodes and 3 modes for each group, so even if you're talking about programming all three groups and not just one, that's 9 submodes maximum.
While you complained about the interface being unnecessarily complex, your solution
was to add even more complexity, technically speaking.
