Hi guys,
So I ran this flashlight on High for circa 15 - 20 mins yesterday while leaving it lying horizontally on a wooden table. I did this because I used it as a source of illumination for something that I was doing.
When I grabbed the unit to shut the light off, the body was very hot. It was too hot to hold for more than a couple of seconds in my bare hands.
Is this normal and would it shorten the LED's life?
Thanks.
I believe it is normal based on the output from the LED, but I don't think it will shorten the LED's life if Surefire designed it correctly. If the LED dies or dims significantly due to the heat, Surefire will make it right and fix/replace it for you.
What battery configuration are you running?
