Crazyeddiethefirst
I received my Titan Plus in the mail today. My first impression is favorable. The threads are smooth and easy to operate. Modes change easily when you are firm and quick with changes. If you turn slowly or just a little, then the mode may not change or you may cause flickering. When I twist it with intent, the mode changes every time. The LED is well centered, but when I compare the Titan A and Titan Plus side by side, I realize my Titan A was off center just a little bit. There has been a lot of discussion as to whether Surefire used a sealant or O rings on these lights. When I look at both of mine, side by side, it appears they are O rings, and even though I can see the seal around the entire circumference of the light, more of the ring is exposed on one side of the ring than another. It appears to have nothing that would cause water to enter, but aesthetically it would look nicer if the amount exposed was consistent so I do think that QC decided that if it was not functionally significant to let it go and on an $89 light I would expect a little better. The beams on both are a little diffuse with moderate spill, and I would say midrange between cool & neutral with no green in either of my lights. Now the question that everyone has been asking: does it put out 300 Lumens. My answer 5 minutes after I opened the package was "Yes, it does put out 300 Lumens". A couple hours later and I have to amend it to "I am not sure". Before everyone calls me an idiot(and that is a possibility), I did a couple side by side comparisons and it looked very comparable to 300 lumen lights. Then I decided to see if it would put out 300 lumens for an hour. What caused my confusion is this: after 30 minutes on high, my eyes detected no change in the brightness of the beam, but when I turned on my Titan A to go to another room, all of the sudden I realized my 125 lumen light was about the same intensity as my 300 lumen light. So I "cycled" the Plus back through L-M-H, and suddenly the high beam was more than twice as bright as the "A" model. I checked my voltage, and the Plus was at 1.08 volts. Obviously I need to do some further research to give a more definitive review. But first, a couple more tidbits;
The instructions say the plus can run on NIMH, Alkaline or Lithium...doesn't say "Lithium Ion rechargeable or L-91
Lithium...so, being the intrepid adventurer I risked my brand new $89 Titan plus with an Energizer Lithium(worked fine) and also a 4.2 Efest(apparently Surefire expected this be the case and built in protection-the light will not turn on with the 4.2 Lithium.
The pocket clip on my Titan Plus is very secure. It is easily removable by following the instructions. The external cap clip would have impressed me a year ago, but since I have had an Olight I7r on my key ring for quite a while, I am spoiled. I keep my Olight on the "high" setting and when it comes off accidentally )a very RARE occurrence), it instantly catches my eye. The concept of a keychain light easily removable is a good one, but both Olight & Prometheus have done a slightly better job. That's it in a nutshell and I will try to post some photos as time permits.
