PoliceScannerMan
:huh:
Frank,
I am told the input voltage range for the converter is 3.6V - 9V. Two cells of primary or rechargeable will be no issue for the converter.
At 1000 mA, the Makai 6V demands less of a single CR123 than does the Makai 1x123 so when used with 2x123, your run time will be greater than double that of the Makai 1x123 and you will be generating more light on high than does the Makai 1x123.
At 1000 mA, the Makai 6V demands less of a single CR123 than does the Makai 1x123 so when used with 2x123, your run time will be greater than double that of the Makai 1x123 using 2 cells one after the other and you will be generating more light on high than does the Makai 1x123.
No : if you use two cells one after the other in the 1x123 Makai you will have a greater runtime then with the 2x123 using two cells at once. Re-read my post.
This is exactly why you need to knock out physical laws.
No problem Don, brain fart happens to everyone occasionnaly, even the best
