tino_ale
very KISS and no hassle, NICE!
The MCRxxXR series have an O-ring groove. I install an O-ring around the reflectors then position the reflectors so that the led end is facing up. Then I insert each LED into a reflector and apply a thin coate of thermal adhesive. Next a slide the head with heatsink installed over the LED - Reflector assembly. If the reflectors are tight fit into the head then you are done if not you can flip everything over and center by eye. If there is alot of room I will make a quick PVC spacer as a guide then remove the spacer once the adhesive sets up.
Mac
