Upgraded emergency light, $25
Skelshy
I have a couple of Costco 3AA lights that all self-drained their batteries within a year. I need a light that's there when I need it :)
These are for stationary use, cars, trailer, motorcycle, backup for house. They need to fit in a glove compartment, but they are not going to get carried much when not actively in use. A wide beam is preferred. I'd like the light output to be even over the life of the battery. A battery indicator would be killer, but I am OK with just following a replacement schedule. It needs to provide light for ... that's a good question. Let's say though the night on a medium setting.
Battery type is not a big issue - I don't plan to run out while away from stores, or I can put a spare with the light.
==================Flashlight Recommendation Checklist================
X_This will be mail-order or Online (location doesn't matter).
China is OK (Can wait for shipping)
2) Budget: An easy question, but you may change your mind after answering the rest! :)
X___Up to $25.
I'm a value buyer - I can spend more if there is a good reason to. I'll spend less if I find what meets my needs for less.
3) Format:
____I want a flashlight (hand held/self contained).
4) Size:
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
Fit in glove box
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
Don't care. No brand affiliation
Anything other than rechargeable.
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
I would err on the side of caution and say 400+. Really want a wider beam.
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
Cool
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
___30-60 minutes (I have plenty of batteries just ready to be changed)
Body or tail, no twisty
____I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
____I don't care.
15) Water resistance
____IPX4 (Splash resistant) or better
16) Storage conditions
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
Battery indicator would be cool, but might narrow the field too much / make it too expensive.
Thanks.
Dave D
Andalusia, España
Rayovac Workhorse Pro 2AA Virtually Indestructible Flashlight, RRP of $19.99, put two Lithium AA batteries in it and forget about it until you need it.
