i understand the need for more light during the day. your eyes are adjusted to the ambient light, so low is not effective when you need to peak into darker spots.
i use my light much more during the evening hours, so i prefer low first like most others
. i dislike having to cycle to low from high because you get this bright flash.
and i am probably in the minority here about have L-M-H or any 3 mode cycling. cycling 2 modes is as much as i want to go. fortunate for me surefire makes my ideal UIs in the function of 2-mode clicky w/o memory, 1 or 2 mode momentary, or 1-mode clicky.
my work lights on the other hand, comes on high first. or high only. i work at the airport, and even at night there is a lot of ambient light that my flashlight needs to overcome. but for more casual EDC uses, low is what i use 90% of the time. the low on my surefire L1s range from about 5-10 lumens. which is more than i need, but its always better to have more light than needed, than less light.
surefire L1 gives me instant access to low or high, without any kind of bezel twisting, or clicking, and ive found it ideal for my edc use.
there are quite a few lights which use a single AA, that you have control of it turning on high or low first by its bezel position, usually bezel tight for high or bezel loose for low.
