Will 14500 batteries (rechargeable) work in most AA 2x lights?
MTHall
I want to get a charger that will accept both 14500 and AA batteries. Can I use both sizes in most Olight, Fenix and Nitecore 2AA lights?
Thanks very much.
ilikeguns40
Western PA
You would only be able to use one 14500 3.7v with a dummy AA. Using two 3.7v 14500 will put the voltage around 7.4v and will more than likely fry the LED. I recommend using Eneloop AA rechargeables
14500 are the lithium ion version of a AA that are 3.7v
AA Primary batteries voltage are around 1.5v
troutpool
Arizona
Yes, be careful with this. Look up and know the voltage range each light is rated for and don't exceed the maximum. Using one cell and a spacer in a 2-cell light can be a good option sometimes.
Hooked on Fenix
No. Most only work with alkalines, NiMH, and maybe lithium primaries. Some can go up to 4.2 volts. Very few can handle 2 14500s. The Fenix LD22 V2.0 will work with 2 14500s.
PhotonMaster3
I can confirm that. A few years ago I stuck a pair of 10440 batteries in a Nitecore pen light designed for AAA.
Ha well the brightness was great… until it fried a few seconds later
