lightmyfire13
- Joined
- Jul 27, 2012
- Messages
- 413
Bit off topic but my victorinox leather holster fits perfectly. ......
yep.......I got this light last night. A few initial comments (others have shared the same things)
- The tint is beautiful
- Output is sufficient but doesn't blow you away like the SC600 MKII
- The annodization isn't nearly as nice as my SC52 or the SC600 MKII. It's a little more slippery and feels cheaper. The annodization on my SC52 is just perfect, but the SC62d left me a little disappointed to be honest.
- The switch is squishier than the other ZLs but not really a problem.
Overall I like it, but it doesn't wow me like my SC52 and SC600 MKII.
I had a sc62 but felt it needed more output. Nice light, felt great, lightweight with a nice beam but would have been better with a turbo blast but the high setting is just right for daily use. And my sc600 II has a 300 setting with more runtime than the sc62 so the sc600 is more versatile and the same cost.Maybe the SC62 is as hard to produce as a SC600 but feel due to lower output can't justify the same price?
When I asked them about potential SC62w I was told:
"The board space is bit smaller than what we can manage (production wise) right now. The H600/H602 has a slightly bigger space. But I am sure sooner or later we'll be able to find some smaller components and make it happen."
I have asked why not just focus on runtime and spec it similar to a SC52w and jam the guts from one of them in so will let you know what they say.
From that statement above, it seems they want to have the same hand-frying-high as a SC/H600 which I think is waaay off the mark.
SC62 feels better than a SC52 in my hand and I sure wont notice the lumen deficiency on 500L if it lasts a decent while!!!
I asked why SC52 electronics could not be installed with the possibility of having a slightly brighter high. I certainly don't feel the need for 1000+ lumens from a light this size.
This is their respose:
Thanks for your suggestions. George, the man behind all these flashlight/headlamp designs, wanted to have a full blown XM-L2 version similar to the SC600/H600. From what I know, some components such as the extrememly high resolution temperature sensor have gotten in the way that the production process might be too difficult to manage (for example, each SC600/H600 has to go through a lengthy time consuming calibration process to set the PID parameters). I'll pass along your suggstions of having a 'not so fancy' SC62/SC62w that can be produced right now.
I like the SC62d as is. I'm not fond of a drastic timed step down or a super high turbo that makes the light too hot to hold. Before the SC62, I only ever used my SC600 in the 356 lumen setting. Loved the output and runtime, but I was willing to sacrifice a little of each for the smaller form factor of the sc62. Tint is awesome and the beam pattern is also nice change in the current sc62. Just my personal preference.
But I have 16340 lights that are 3x as bright and half the size. And 18650 lights that are similar in size and 5x as bright.
Do you mind posting here those lights or PMing them to me? Sounds good!
Actually in reference to 16340 lights I was thinking of my Xtar WK42. It's smaller and lighter than a Zebralight SC52. In stock form it comes with a cool white XML U2 and outputs 300 lumens on high. It also feels beautiful in the hand.
I performed the following mods on mine:
1. Replaced emitter with 5000k XM-L2 neutral white emitter.
2. Replaced stock aluminum star with Noctigon direct copper star
3. Drilled out part of the inside of the head to allow room for a deeper driver.
4. Replaced driver with 3.04 amp Nanjg 105c with DrJones lumodrv firmware. This firmware has an awesome UI: click and hold from off to start at moonlight and then ramp up. Click and hold again to ramp the other way. For ramping, the driver has 34 visually linear brightness steps. Release the button at any point during ramping to stop ramping. Double-click shortcut to max, triple-click for 25%, Quadruple-click for strobe, Quintuple click to enter momentary mode. Single-click from off to turn the light on in last used mode. To turn off the light, click once from on after waiting 2 seconds since last pressing the button. The UI also has hidden blinky and strobe modes, a battery voltage meter, and built-in low-voltage stepdown and cutoff. The shortcuts are also all programmable.
5. Replaced stock switch with Radio Shack micro-momentary tact switch.
6. Replaced driver wire with with 22 gauge silicone
7. Solder-braided the tailcap spring to reduce resistance.
I run the light on IMR 16340 cells. Output at the emitter is around 1100 lumens, which should translate to around 900 or so out the front. It's much brighter than my SC62d or even my early model SC600. Runtime at max power isn't long (about 12 minutes) ... but that's what intermediate modes are for.
Thanks, Fireclaw.
It sounds like you are saying that the stock SC52W is brighter with better tint than the stock WK42.
A bit misleading to say you have others that are 1/2 the size and 3x as bright and leave it at that before coming back later to add the asterisk. If you make half a dozen major mods to any light I'm sure you could turn anything into a hot rod. That's not a revelation nor should it really be counted against anything stock.Different people have different preferences. Usually my EDC gets used for brief periods only and is recharged everyday. So I don't need a runtime king. The SC62d is a nice light, with a good tint and small form factor for an 18650. But I have 16340 lights that are 3x as bright and half the size. And 18650 lights that are similar in size and 5x as bright. Good tint is nice... but doesn't quite make up for not having good output. And if I want longer runtime... that's what medium modes are for.
Is there any runtime graphs for the sc62?
What voltage does the battery have when you get 1,2,3 or 4 blinks from the batterymeter?
At what voltage does it step down from hi to med and from med to low?
Maybe it's out there but I haven't seen it.
I find it more interesting or at least just as interesting to know how much runtime I have left when I get an indication that the battery is getting low than just knowing total runtime with fresh cell.
Zebralight SC62d @145 lumen / AW 2900 mAh | ||||
Time | Voltage | Flashes | ||
(H2 - 145 lm) | Test #1 | Test #2 | Test #1 | Test #2 |
00:00:00 | 4.18 | 4.18 | 4 | 4 |
01:00:00 | 4.03 | 4.02 | 4 | 4 |
02:00:00 | 3.91 | 3.90 | 4 | 4** |
03:00:00 | 3.75 | 3.74 | N/A* | 3 |
04:00:00 | 3.66 | 3.65 | 2 | 2 |
05:00:00 | 3.54 | - | 2 | - |
06:00:00 | 3.28 | - | 1 | - |
06:25:00 | 2.97 | - | 1 | - |
