Re: ZebraLight SC600 MkII interface and tint observations
Doing a ceiling bounce test is a pretty good way of approximating relative lumen output between two lights. You're still seeing lux, but it's cumulative lux created by indirect light, so the change in this lux number is going to be approximately the same as the change in lumens.
Even with the same hotspot, 90 lumens isn't going to appear all that much brighter than 42 lumens. With binning and manufacturing tolerances (regarding lumen ratings), plus Zebralight's history of ninja LED upgrades, there's no way to know what the actual output of a light is without individually measuring it.
True, but we suck at lux too.
What I have found is that if I shine two lights at a wall, one has to be a lot brighter to tell, especially if the beam angles and proportions of hotspot to corona to spill are different....there's too many variables.
But, if I set up a series of targets in a fan shaped pattern with various distances, so that the full beam width and depth are illuminating targets, the one with even slightly more lumens will light up more total targets.
So, in real life, say if you are searching outside, or in a warehouse, etc, and you can see more of what's out there at a time, those extra lumens can actually make a difference.
If you are hunting white walls, or just want it to LOOK brighter...it has to be a lot brighter to notice.
Same on a bounce test.
The throwier lights will be bouncing back down from a more centralized spot, and the floodier lights will be bouncing down from a less centralized spot.
As most people bounce test with a meter right under the light aimed up at the ceiling, this will tend to favor throwier lights (Tighter focused beams).
I've seen light meters with bounce tests vary results for the same light by simply having some clothes hanging on something or not, the kitchen sink being full or empty, or different stuff laying on the kitchen table, and so forth.
So, if I compare a Mk1 to a MkII, I can tell the difference in targets lit up, and with a light meter, but, if I am only seeing the beam of ONE of them, with a new scene I have not shot before, without a chance to COMPARE the beams, I would have a hard time guessing which light the beam came from....I'd need a reference point to compare to have a shot at that.
That means I could buy a new one, and randomly turn it on, and not be able to tell it from the old one. It doesn't mean it wasn't worth it per se, because I'd see more STUFF with the new one, I just wouldn't know it unless I had reference points.
It might be like comparing two runners w/o stop watches.
John and Fred are both fast, but John does the mile in 3:50, and Fred does it in 4:20.
Without a stop watch, or seeing them side by side, or against other racers, you'd be hard pressed to say who was faster if you saw John run it at one track in January, and Fred run it on a different track in July.
John and Fred are out camping, and are charged by an enraged and famished Grizzly Bear coming at them from 100 yards away. They turn and run the other way as fast as they can. Would you rather be John, or Fred?
You could not tell the difference, but, it might matter anyway.
