Kif
I collect Surefire flashlights for years and this is my first time pre-order New Surefire flashlight. This is the first Surefire official made flashlight using 18650 rechargeable battery and I want to be the part of this history.
I ordered the B version which has dual LED output. 600 Lumens on high and 15 Lumens on low, and with clicky type tail cap.
The following are the photos
front side of box
back side of box
600 lumens with 1.75 hrs run time and 15 lumens with 46 hrs run time
box open view
P1R flashlight
18650 battery charger
using with indoor power cord
using with car 12V adapter
back side of the 18650 battery charger
the included 18650 is 2600 mAh
the battery was made in June 2014 (?)
It finally has newer CREE XML2 LED
Size comparison with Fury P2X and P3X
The lumens of the P1X is between P2X & P3X and the hot spots are all very similar. The P1R will be very handy in actual use even with a little bit expensive than Fury P2X
Update:
Post a photo with head battery contact side
There is a small spring like other newer Fury/6PX/G2X
It can use flat head 18650 without any problem
I only have AW protected 2600 mAh 18650 so I am not sure if the P1R can take bigger 18650
Top to bottom:
AW protected 18650 2600 mAh
Surefire 18650 2600 mAh
AW protected 18650 2200 mAh
front side of box
back side of box
box open view
P1R flashlight
Update:
Top to bottom:
