Triple v5 R33 Engine - 4th LED, 30w limit, Screen Programable, Dual Mode Groups
ElectronGuru
Oregon
v5 Thread TOC
A) Feature Grid
FeatureBOSSE HeadWaspDropOld Ex300
30w maxxxxxxx
sublumen lowxxxxxn/a
33 levelsxxxxxn/a
3 memoriesxxxxxn/a
battery modesxxxxxx
auxiliary colorxxxxxn/a
programmingxxxxxx
battery stretchxxxxxx
thermal stretchxxxxxx
bounce modexxxxxn/a
swappable opticsxxx
GID ringxxx
replaceable boardxxx
direct air coolingx
E bodiesxw/adapterx
P60 bodiesx
x300 bodiesx
B) Levels & Colors
C) Select Levels
1 cell
NameLetterLevel #Power
MiliwattsLumensRuntimeStretchtime
redR6tbd
dimD10.005%1.50.18tbd
lowL140.6%1802023h
mediumM2110%300034693m91m + 16m
highH2855%1700019338m7m + 18m
2 cell
redR6tbd
lowL161.4%4004623h
mediumM2422%650075860m58m + 21m
highH33100%30000349810m8m + 36m
  1. runtime: 800mah 18350 with stretch turned off and 2.8v battery protection on
    stretchtime: 800mah 18350 with stretch on, declining at 3.2 and stopping at 2.8
    stretch combines [continuous output level] + [gradually declinding output]
    for larger cells, divide mah by 800 (3400/800 = 4.25), then multiply by [time][/B] [*]values for initial settings, channels can be changed or disabled values are for XPL, 219C values are less (24w max) [*]lumens: rated from the LED, at 25C. OTF will be less [*]to maximize longevity, change your cells at 3.2 (when stretch starts to dim) [/LIST] [HR][/HR][B]D) Serial Number[/B] 1. Put your light into programming mode (2+2+2+ON) 2. Wait and watch the dim red light 3. Count the bright red flashes, grouped into six digits (repeats: 123456, 123456, 123456) 4. [URL="http://lux-rc.com/content/serials"]Open this page[/URL], enter the digits, and click Check: [CENTER][URL="http://lux-rc.com/content/serials"][IMG]http://www.oveready.com/images/forums/v5serial1.png[/IMG][/URL][/CENTER] 5. Read your values on the next screen (white box shows firmware version): [CENTER][URL="http://lux-rc.com/content/serials"][IMG]http://www.oveready.com/images/forums/v5serial2.png[/IMG][/URL][/CENTER] [HR][/HR][B]E) Voltage PIN[/B] [LIST=1] [*]place your v5 into voltage mode... [*]1 short flash + off for one second, three times... [*]on, pause, on, pause, on, pause, ON (1+1+1 demonstrated below) [*]white = whole volts (per battery) [*]color = tenth volts (per battery) [*]so white/white/white/red/red/red/red is 3.4v [/LIST] [CENTER][MEDIA=youtube]UKMu_XOdYdg[/MEDIA][/CENTER] [HR][/HR][B]F) Programming instructions[/B] [LIST=1] [*]place your v5 into programming mode... [*]two short flashes + off for one second, three times... [*]on-on, pause, on-on, pause,on-on, pause, ON (2+2+2 demonstrated below) [*]red or amber shows dim, then starts flashing [*][URL="http://www.oveready.com/prog/"]load your favorite program[/URL] [*]hold your v5 light to the green square on the screen... [*]one full green/green cycle -> until the red/amber turns off* [*]turn your light off for 2+ seconds [*]turn your light on and test your new configuration! [*]* if 7 doesn't take (LED stays on), confirm dim/blinking and turn up screen brightness [/LIST] [CENTER][MEDIA=youtube]1CybBgiFJl0[/MEDIA][/CENTER] [HR][/HR][B]G) Factory Modes [/B] Configure your light back or over to one of six standard setups: 1 RLMH RLMH [IMG]http://oveready.com/images/forums/V5%20-%201%20RLMH%20RLMH.png[/IMG] 2 HMLR HMLR [IMG]http://oveready.com/images/forums/V5%20-%202%20HMLR%20HMLR.png[/IMG] 3 RLMH HMLR [IMG]http://oveready.com/images/forums/V5%20-%203%20RLMH%20HMLR.png[/IMG] 4 DLMH DLMH [IMG]http://oveready.com/images/forums/V5%20-%204%20DLMH%20DLMH.png[/IMG] 5 HMLD HMLD [IMG]http://oveready.com/images/forums/V5%20-%205%20HMLD%20HMLD.png[/IMG] 6 DLMH HMLD [IMG]http://oveready.com/images/forums/V5%20-%206%20DLMH%20HMLD.png[/IMG] [HR][/HR][B]H) Special Tactical Configurations [/B] 1x18650 + 2xCR123 Safe Lower output on two cells, for when two cells is always CR123 (primaries) [IMG]http://oveready.com/images/forums/V5-9%20HMLR%20IMR%20HMLR%20CR123.png[/IMG] Hidden Second Mode To have a second mode but make it hard to get to, bury it three clicks deep: [IMG]http://oveready.com/images/forums/v5hidden3rd.png[/IMG] or four: [IMG]http://oveready.com/images/forums/v5hidden4th.png[/IMG] [HR][/HR][B]I) Advanced Settings[/B] After-timing, programming videos (right click to save) [I]How long your light waits before pressing [B]slower[/B] = start over[/I] [LIST] [*][URL="http://www.oveready.com/videos/0.25.mp4"].25 seconds[/URL] [*][URL="http://www.oveready.com/videos/0.35.mp4"].35 seconds[/URL] [*][URL="http://www.oveready.com/videos/0.45.mp4"].45 seconds[/URL] [*][URL="http://www.oveready.com/videos/0.55.mp4"].55 seconds[/URL] [*][B][URL="http://www.oveready.com/videos/0.65.mp4"].65 seconds[/URL] (default)[/B] [*][URL="http://www.oveready.com/videos/0.75.mp4"].75 seconds[/URL] [*][URL="http://www.oveready.com/videos/0.85.mp4"].85 seconds[/URL] [*][URL="http://www.oveready.com/videos/0.95.mp4"].95 seconds[/URL] [*][URL="http://www.oveready.com/videos/1.15.mp4"]1.15 seconds[/URL] [*][URL="http://www.oveready.com/videos/1.25.mp4"]1.25 seconds[/URL] [/LIST] Temperature, programming videos (right click to save) [I]How long your light waits before reducing output to stop further heating[/I] [LIST] [*][URL="http://www.oveready.com/videos/30c90f.mp4"]30C / 90F[/URL] [*][URL="http://www.oveready.com/videos/35c100f.mp4"]35C / 100F[/URL] [*][URL="http://www.oveready.com/videos/40c110f.mp4"]40C / 110F[/URL] [*][URL="http://www.oveready.com/videos/45c115f.mp4"]45C / 115F[/URL] [*][URL="http://www.oveready.com/videos/50c125f.mp4"]50C / 125F[/URL] [*][URL="http://www.oveready.com/videos/55c130f.mp4"]55C / 130F[/URL] [*][URL="http://www.oveready.com/videos/60c140f.mp4"]60C / 140F[/URL] [*][B][URL="http://www.oveready.com/videos/65c150f.mp4"]65C / 150F[/URL] (default)[/B] [/LIST] Loading above erases your program, restart and reload modes before use F values are approximate. All values are interior, exterior will be less[/time]
Grizzman
KC Metro
I just read the Insider. The battery swap mode groups seems like a great solution for me. I was going to get single mode for tactical use, but now that's not necessary.
IsaacL
USA
A huge congratulations on the overwhelmingly successful release! :thumbsup: Love the picture too ;)
ElectronGuru
Oregon
Thanks. It was a huge amount of effort over a huge amount of time but I think it was worth it :)
We are going to want to hear a description of the tint on the dome altered XPL's. And how long can the XPL 2 cell configuration run on high.
Certainly.
We developed a new way to show color but could not include it without postponing the release.
I can say its about 4000k but will need a few weeks to actually show it.
Here are the runtimes I've been able to finish:
1 cell
redR6tbd
lowL140.6%1802023h
2 cell
redR6tbd
lowL161.4%4004623h
These are XPL on an 18350/800. Figure about 4.5x more for 18650/3400
R33- xpl redome.. Is it the same as factory xpl-hi?
These are custom. Non HI model, with the dome removed and then a smaller dome replaced.
We can choose the size of the new dome in this process. The shorter it goes, the more throw it has.
We went as short/warm as we could go and still be near white.
ElectronGuru
Oregon
Nice, are you gonna release the whiter xpl-redome in near future sir?
These are already very close to pure white. We could do a cool but with less throw. Warm is also an option but not doing that for a few months at least. We've invested months developing this color, lets see how the early adopters feel before altering it.
ElectronGuru
Oregon
Thanks Dude, I was planning to go with a sliced image as I've done with various GID parts but the presentation was off so I changed to a split screen view. Even that didn't look balanced, but adding the logo fixed that right up :D
KITROBASKIN
New Mexico, USA
With 2 18650 batteries, how long can you run on high before it gets 'too hot' to hold.
By the way, this sounds like a fantastic light. The programmability knocks it out of the park.
ElectronGuru
Oregon
It doesn't. The board is fine up to 120c but that is to high for humans. So there is a thermal management system that monitors the temperature in real time. As it runs into the set limit of 65c, power drops in 1/33 increments. Output is kept as close as possible to the set power level within the thermal limit, for the entire discharge of the cells (until 3.2v per cell).
In practice, its smooth and nearly seamless and is one of my favorite features of the new board.
