Manker
- Joined
- May 5, 2016
- Messages
- 111
UPDATE: Manker E14 (4*Cree XP-G3/ Nichia 219B/ Nichia 219C) is releasing
Update: E14 Cree XPG3 and E14 Nichia 219C are available.
More details please visit: http://www.mankerlight.com/manker-e14-cree-xp-g3-nichia-219b-led/
Cool EDC flashlight Manker E14 runs of 1 x 18350/16340 battery/1*CR123A/1*RCR123 is releasing.
Specification:
Emitter Type: 4*CREE XP-G2 / 4*Nichia 219B
Circuit Driver: A17DD-L FET+1 Driver (BLF A6)
Light Tint: XPG2 (6500K) / 219B (5000K),
Material: Aero grade aluminum alloy & copper
Mode:
Group 1: Moon-Low-Med1-Med2-High1-High2-Turbo(Short press<0.5s)
Group 2: Low,Med,High,Turbo (Short press<0.5s)+Moon-Turbo-Tactical Strobe-Battery check-Bike Flasher(Medium press 0.5s-1.5s)
Battery Configurations: 1 x 18350/16340 battery/1*CR123A/1*RCR123
Switch Type: Click Switch
Switch Location: Tail of the flashlight
Impact Resistant : 1 meter
Max Output: XP-G2 1600lumens / Nichia 219B 1400lumens
Working Voltage: 2.8-4.35v
Lens: TIR
Waterproof: IPX-8 waterproof 2 meters
Weight: 90g without battery
Size: 80mm x 24mm(length x body diameter)
What's in box: 1*E14, 1*Lanyard, 2*O rings, 1* User's manual(English)
- special-edition with a regulated lower-power second channel for stable and efficient low modes.
- True moon mode.
- Up to 1600 lumens Cree XP-G2
1400 lumens Nichia 219B
- User-toggle-able mode memory.
- User-toggle-able mode groups.
- Well-spaced visually-linear output modes.
- Includes some hidden modes for those who want them.
- Battery check mode.
- Clicky-switch stock light with both forward and backward mode navigation in a single tap (short/medium press).
- With mode memory off, the user can access 4 different modes (including the highest and lowest) within 1 second.
- Fast PWM so the pulsing won't be visible.
- The firmware and the driver designs are available for anyone who wants to modify them.
This little but functional flashlight Manker E14 will be available on Ebay and Amazon very soon.
How do you think about it?
Specification:
Mode:
Lens: TIR
- True moon mode.
