E3A or i3e? Vinh sells the i3e and could drop the output on an e3a for you as well.
E3A, thanks.
fwiw, Skilhunt E3A has a Welcome Deal on Aliex, if you create a new account.
some modding info to reduce output on E3A:
"Output current set by current sense resistor, 0603 SMD size (0805 can be fitted to by my experience). Default value is 0.43 Ohm, corresponds to ~220 mA LED current, according to datasheet formula.
Replacing default current sense R with 10 Ohm reduced LED current to ~9.5 mA, and LED output to ~5 lumens for ~34 hours!"
Oh, duh -- I should have understood that. No, I already have an account with them. Haven't used it since 2019. And I suspect that I signed up only for a Sofirn!I think Aliex = AliExpress. I ordered Sofirns from them once, no problem.
Thanks, Jon! troutpool helped me figure it out. I already have an old (dormant) account on there, so I'm not eligible for a new-account special.It is an online marketplace, like Amazon.
I have bought a number of flashlights from there. the link I gave that lets you buy an E3A for 99 cents, could be a good low risk purchase for you. I ordered one myself ;-).. I pay with Paypal, so there are no trust issues.
But that slate blue one is calling your name...Thanks, Jon! troutpool helped me figure it out. I already have an old (dormant) account on there, so I'm not eligible for a new-account special.
Also, it is just possible that I have enough lights??? Nah....
Pretty sure it's doo-doo Borwn.Never seen the doo-doo brown one before.
Oh you are correct sir. Doo-doo borwn.Pretty sure it's doo-doo Borwn.
It is calling my name. But that color doesn’t get you the $0.99 discount. For slate blue, they want the outrageous price of $2.16!! It’s larceny, I tell you!But that slate blue one is calling your name...
that is not a valid runtime test.. right below the chart it says:The hi cri version takes a pretty stout hit when it comes to runtime eh?
Oh wow my fault! I didn't read the fine print! Sorry folks, carry on!that is not a valid runtime test.. right below the chart it says:
"I didn’t test this runtime with a brand new NiMH cell – probably as a result, we’re only seeing around 12 minutes at 75 lumens. With a fresh cell, I imagine you’d get the claimed 75 minutes."
I still find the etching design insane on the olights ..Rovyvon A5.. lowest mode 0.2 lumens, plus 3 other modes (20, 145, 400lm).. includes USB-C charging and High CRI 219c 5000K
Olight i3e single mode 100 lumens, 20 grams w Eneloop Pro, Low CRI
lights are the same size:
I don’t love the new/different body style of the i3e but that’s just me. i1r 2 been on the keyring last two days. Love the size. Easy to turn with captive head so no worries of it spinning off. Low is perfect for key holes and close up stuff and high is…well really bright….but eats battery quick. I’m going to let him hang on the keys for a bit here.
Edit to add that I do like the twist on and then keep twisting for high rather than off and back on to change modes. This ui makes more sense to me. I think 3-5 low and 20 or so on high would be more my speed and provide decent light for a decent amount of time.
www.rovyvon.com
Anybody have experience with them?
agree..a bulkier object
