Minimag 5mm nichia gs
gurdygurds
(Post reserved for updates)
Consecutive days running never shutting off Since April 9, with Yugi 5mm in a Maglite 2D: 90
I have terminated this test due to boredom. There is still usable light coming out of the front. I estimate in the 4-6 lumen range.
Read this post again the other night and decided I'm gonna try to do this. Figured it's a great way to get my Dad's old 2d Mag back in action. Trying to source at least one warm Yuji and then I'll pull the trigger on the bi-pin adapter.
gurdygurds
Sourced some warm Yuji leds and have a bipin adapter en route. Excited to give this a go. My Dad's old 2D Mag is sitting on my nightstand with a couple of fresh Rayovac cells popped in and ready to go. I won't bother doing any sort of runtime test as this setup has been shown to run forever. LeanBurn are you able to post a beam shot of yours? Curious what to expect as far as beam goes and how different it will be from the stock bulb.
this_is_nascar
Gloucester, New Jersey
Let us know how it goes. Where did you get you bi-pin adapter?
gurdygurds
Got this off of Amazon
gurdygurds
Got the adapter and I'm still waiting on the Yujis, so in the meantime I plugged in an old photon led. Works just fine. A little flickering when I spin the head to adjust the beam, so I may need to play with it some more. Also ordered (finally) an orange peel reflector from Kai Domain and a glass lens. I'm officially ready for the Texas power grid to go down again this winter now that I have never-ending light. 👍🏼
gurdygurds
Yujis have arrived. Thanks Nascar! Now just waiting on the reflector and lens from Kaidomain. Probably going to look for a used incandescent Mag for a good price to use for another Yuji runtime monster. Maybe a 2xaa but I'm really liking the idea of the insane amount or runtime off of 2D batteries. Open to host recommendations. Maybe something that is already bipin so I don't have to buy another one of those. I'll post photos once I get the rest of the goodies.
EDIT: Just found the bi-pin thread so I'll continue there.
snakebite
dayton oh
Did not run a pair of fresh primary lithium AA's for very long but the amount and quality of light was impressive indeed.
Also used a piece of wood and copper foil strip to make a dummy battery with a 10440; not a good idea. The emitter turned color in a bad way. I turned it off quickly and it was OK. It's funny because 6Volts (pair of 2016's) is Ok in a Photon pinch-flashlight, being significantly brighter than a single 2032 battery. Guessing low current/capacity of coin cells matters.
By-the-way, decided to take the turquoise emitter out of the Minimag and installed it in a vintage Photon Freedom with covert nose; much better with the 6V making the tint what it is supposed to be.
Take a 14mm dowel rod and drill it in the center.
50mm long.
Now put a resistor inside the dowel with a screw on positive that emulates a aa + contact.
And screw with wide flat head on the - end.
Select resistor to get target current.
Drop it in the minimag along with a 14500 li ion.
