Sort of tired of the China budget level charger and it is becoming apparent that I need to be able to do do a controlled discharge to test the mAH performance of the cells. I am not sure if there is a slick package to both charge and test or if this will be two devices? I am not looking for the pro level system, just something rather basic.
I assume one could probably just charge a battery, then just use a power resistor and record time to discharge to min V with the DMM but I assume there are some simple testers that make this easier?
I think I should probably clarify my goals for needs for battery testing. I simply want to arrive at an estimated mAH performance. something I can document per cell and track. i build electronics and not opposed to making something but somethings are too cheap to make. Or maybe this is deal simple? We need a constant discharge rate? What rate is that for the standards of the cells and how they are typically used? if anything like lead acid, they are probably rated at a fraction of their actual use so the performance drops?
I have read all the good and bad with 18650 cells and seems it is better to just know what ya got. I would like to at least know.
