Re: A Little Accident. Enjoy.
I'm new to this image hosting business. I'll see if I can't get a smaller version to post here.
Looking at the image of the burned battery's label, you can see the faintest hint of blue or green. The problem is, with all the other features of the image, you can't make out what the blue-green might be.
First I used GIMP's color enhance feature a few times, to better see what was going on, in a small area I had selected as active. Then I adjusted the red, yellow, and magenta channels to greyscale and dark. This had the effect of squashing everything non-blue/green to the black end of greyscale. Last I saturated and lightened the blue, cyan, and green channels. The end result is that any pixels that had even the slightest hint of blue or green became very bright, and all pixels without blue or green were made nearly black. Nothing has been added or interpolated. The smearing and big pixels are the result of original image compression and probably the nature of the camera's sensor (color-sensitive elements are spaced relatively few and far between compared to greyscale-sensitive elements -- your eyes are the same way).
Here's that smaller image:
And here is a smaller version of the other image. The processing is more or less the same, but I think I also contrast enhanced it by equalizing its histogram, and the whole image was processed to make the comparison between the two batts.
Scott
PS: Oh yes, they deserve credit for providing a hosting service so simple that even I can figure out:
Thanks to ImageShack for
Free Image Hosting
