I'm Glad this thread got bumped as I plan to use
FiveMega's 4.5" Par 36 Mag head with one of JimmyM's Fantastic Regulators, and was wondering about different lamps.
I know it will end up looking like a crazy big Mag ( I'll probably use a 6D), but I love the Idea of a far reaching pencil beam...so it seems like Good Fun
I had basically Googled all I can on these, and there isn't too much info..at least not on overdriving, but FiveMega has hit the 4509 with 4 x IMR cells, so I'm guessing 16.4V peak ( My IMRs usually settle to 4.1V fairly soon after charging,) and I guess under load they drop quite quick also...So I was wondering what to set the regulator at So any V lamp readings taken on these would be good to hear.
I had read, and thought of getting the Q4509, as the extra Lamp life and increased rated output was appealing, but I guess it pops easier, and I do wonder if an overdriven 4509 is better than a Q4509 driven at spec, as it seems much higher and
...but also wanted to discuss some of the beam characteristics of the Par 36 lamps..4509, and lower wattage lamps.
I can see me doing all kinds of fun stuff like 6V lamps on 2D mags etc.
I could look at the 24V lamps, but will stick to the 100W for now, unless there is a 150W out there. ( but cant find one in the ~12V range)
So what are some of the better or prefered Par-36's, with regards to nice beams, A nice pencil beam seems fun...it would be good to have it quite far reacing so I think a realy fine spot may be good/ fun, although If I can have reach and a bit of spill it wouldnt be too bad.
Also is there a big variation on different manufacturers of the same lamp Numbers I have seen dotted about the web?
I'm in the UK I can find the 4509 here but seem to be two different types of the 4509,
the one here is cheaper than
this one.
What does the 'X' stand for with the slightly more expensive one?
