Capolini
Banned
Was that for me or MC408?
I just staged them according to size, not most favorite!
My top 5 PRIMARY lights in order would be.
1.TK75vn
2.K40vn
3.TK61vn
Four and Five have not been decided b/w the TN42vn and the OSTS TN31mb
Thanks
Now if Mt. Electronics have the same BT[At least the same size/method] they should work fine!! More analyzing for me!
You know Roberto, life can throw all kinds of stuff at us, good........bad.......ugly.........but hey, reading for the 2nd time your post, i thought the same thing. That is simply what a great problem to have in this world today
What i would do, simply just get a few cells(does not matter what light from) and use the light carrier as a test rig. Try out a few different brands, see which just sits right and order 4 of. Or better still, a matching 4 that will fit snug, swap over with the 30Q cells. Button tops should help out ~2mm, this should make the difference from flat top loose, button top secure.
The soshine iirc are pany B inside, those will light up that xhp35 HI nicely in the tn42vn, it is not asking a lot and maybe a way of prolonging retirement. If they can cope with capo on his walk, still have some left in the tank for emergencies. If they rest at 3.3v or 3.5v is neither here or there as they can cope. Just an example.........
Ah good point. These are 66mm long
1.TK75vn
2.K40vn
3.TK61vn
Thing is, your unlikely to go out with the tk61vn and tn42vn at the same time after your recent testing(presumption and one should never presume!). So just swap cells over for when you use the tn42vn. Even if you just pay $8 per cell, its a saving of $32 of which imho no need to spend. Look at it that you are getting even more value out of the cells purchased. After all they have a shelf life(so to speak). Then maybe later on in the year, maybe the year after next when they get tired, replace for some all singing/dancing latest hybrid beasts..............not that the light needs them, i just got carried away
Happy birthday Cap!
Impressive lineup of throwers you have... as I expected !
