reneir0492
my sf e2l and the led lenser 7438,seems like the surefire e2l has less focus but very bright, the led lenser is more of a long distance.
I just measured the physical height of both a Lux III and a SSC P4. The Lux measures exactly 5.80mm and the SSC measures exactly 5.00mm.
1. How important is it to have the top of the dome of the SSC at the very same height as the Lux it is replacing as it relates to focus?
2. Is it the height of the die or the dome that will cause changes in focus after the mod?
3. For those who have done the mod, either with or without the copper disc, was there any change in focus? Particularly in regards to the narrowest beam setting.
I want to make sure that I still have the ability to focus down to the smallest focused spot for the longest throw.
Thanks!
I experimented and found that I get a much tighter hot spot and more throw with the SSC topped out at a hair under 13/32". The actual sweet spot seems to be at 27/64" b/c you get a very round beam at this height (but it is also more floody). At 13/32" the second layer of the beam is a little more on the square side (not unusual for optic lenses). But, thanks to the focusing head, you can just back it off a bit to get a more rounded beam!
So did you use a copper disc to get the proper height?
13/32" = .40625" just a hair under this is best height for SSC in Hokus Focus = .406"
Height of Lux in this stock light is .4115"
.2283" = Lux LED height
.19685" = SSC LED height
.2283" - .19685" = .03145" = difference between heights of Lux and SSC LEDs
.4115" - .406" = .0055" = difference in height between stock Lux and desired height of SSC in the light
.03145" - .0055" = .02595" how much higher the SSC base needs raised for optimum focusability.
Soooo, this all being said, some AA and a copper disc .015 thick should do the trick to get the SSC to the proper height.
Got a form to fill out for a free keychain flashlight from Coast (and $3.00 s&h) with my new light. Sent mine in. Was just wondering if anyone else sent in for theirs and what kind of keychain light do you get?
Picked up one of these today. I'm impressed!
hello eng paul do you have any lenser focus moded p4 seoul led torches for sale.kind regards p.stuartI have Seouls on the way too....one is predestined to go into the Coast. Like you said, this is really a light worth having!
You mentioned the head unscrews easily. I tried to unscrew mine before (just by hand), but didn't want to mess up the focusing system. So I just need to try harder and it'll unscrew? I have strap wrenches, if needed.
Does anyone know what happened to EngrPaul's pictures for this Seoul LED mod guide? It appears that photobucket has taken the pictures down, so can anyone please help by mirroring them or hosting them elsewhere? Thanks!
PAGING FLASHCRAZY
EngrPaul is taking a hiatus from CPF (temporarily we hope), and I suspect he probably removed the pics from Photobucket to gain extra space.
I'll have to post some pics with a how-to sometime. The only difference in my mod is that instead of shimming the emitter, I shim the heatsink itself.
I wound up putting a piece of copper in, forgetting that mine was actually .017" thick instead of .015".
