Paul_in_Maryland said:I'd be a LOT more eager to jump at a 2C mod if it could accept Pila or Wolf Eyes 168 cells (67mm long). The inability of the 2C to accept these cells is what prompted FiveMega to offer his 2-1/2C Mod. Alas, that mod is no longer available.
Isnt the 168A the same size as a regulated 18650? I fit a pair of those inside of my 2C. I just had to slide the switch forward a few mm's and then mod it a bit so it would accept the switch boot. This did require popping the c clip holding the switch out but :shrug: it still works fine. Remove the anodizing from the tailcap, cut down a spring from the hardware store and you are done.
I guess the 2 1/2 C is simpler (if you have the money) but this mod was essentially free
