Darell
As if I had the time, I'm working on responses to ALL of the list now.
Yes... Chevy is saying that they will produce the Volt. It is a serial hybrid, though GM calls it an EV... with a gasoline range extender. Here is that comment and response from my "EVs won't work" page.Isn't Chevrolet coming out with a vehicle that is a hybrid, but can travel 40 miles on a charge from home? As of now, that would be a good first step, as most people could recharge each night. Even that small of a step would be great for the environment and you could still take the car on a trip with the hybrid system. Hopefully the other car makers will start offering such a hybrid with a short range all electric drive system soon. I'd be buying one.
More like GM has finally figured out an acceptable (to them) way to produce electric cars. Add a gasoline engine to introduce needless complexity. It should break down just as often as any other car, and keep their spare parts business going. Also funny how the 150 mile range of the NiMH EV1 wasn't acceptable, but all of a sudden 40 miles is.GM has finally figured out what the EVs were missing to make them acceptable to the consumer: A gasoline engine. Now, 12 years after the EV1 debut, they just have to figure out how to get 40 miles of battery range.
PDF White Paper (PDF file)What is the most important aspect of Firefly's new technology?
The "key" to Firefly's technology is the substitution of lightweight carbon-graphite foam for much of the lead metal grids found in a conventional lead acid battery. The carbon-graphite foam grids have substantial advantages that directly address conventional battery shortcomings, or, as we prefer to call them, "performance bottlenecks". The carbon-graphite foam is much lighter than traditional lead grid material, it allows for greater electron flow from the battery's chemistry, and is highly resistant to sulfation, which is a common lead acid battery failure mode. Another benefit is much lighter weight and proportionately greater energy density.
So, what do you all suppose would happen if a LOT of people started owning pure electric vehicles, recharging them everyday, or every other day, . . . .when it seems like (especially in the summer time) in large cities, power consumption is up so much, they do "rolling blackouts". If people are also placing electric vehicle charging on the electric grid, would that mean that such cities would have even more problems, perhaps even more times per year?
Very good, then, Darell.
I'll be on board when they realize that "it's time".
