No worries, these photos are awesome! :thumbsup:
I've been specifically wondering about dual AA lights for some time, how they run as headlights - just what your beamshots show. Thanks! If I may ask, a couple of questions:
1) I can't quite see in the pictures how crowded the area near your stem is. Can you kill the need for the bar mount by moving the reflector more to the side and putting both lights directly on the bar, to either side of the stem?
2) I've found over-the-bar positioning to be slightly unstable, have you had a chance to test under-the-bar mounting?
3) Assuming you are running both lights on Turbo, how warm are they after 20, 40, 60 minutes of night riding?
4) Assuming you are running both lights on Turbo, how is the light spill in use? That is, without the headlamp, can you see enough to the sides to feel comfortable that you are seeing enough? Would you consider pointing the lights out from center to improve lateral spill?
5) Assuming 150 (each) lumens out the front, is 300 lumens enough for urban night riding? Would 200-225 be enough? I'm talking volume of light here, not delivery.
6) Is the multi mode tailswitch easy enough: click-on-one, click-on-two, out the door?
7) As you mention, the narrowing of the AA body makes a perfect mounting point. Does using it necessitate opening the velcro every time you remove the lights?
8) How about two dual AAs on the bike and one single AA on the helmet?
9) If they made it, would you want one wide reflector and one narrow reflector? Im thinking of mimicking my trucks top set lens arrangement:
https://www.candlepowerforums.com/threads/173142
