PoliceScannerMan
There actually was a NovaTac prototype nicknamed "the Bumblebee".
We haven't toyed with the idea since.
I would love a polymer HDS, just throwing my name into the hat.
I guess the idea of a polymer light is not bad.
warrioroflight said:But my opinion is that the durability will be not better. Even if it is a very good polymer. The wear will be higher in compare to a metal body. At least this is my guess.
But I like the idea. A lemon yellow HDS would be cool
Says the guy currently searching for an orange G2.
Manufacturing such a polymer light is way more complicated. You need to make outer polymer body parts that than fits perfectly on a metal tube. The head and body Needs some metal for the Electric current… Than the number of parts will be higher that Needs to be machined.Honestly, why wouldn't the durability be better, or at least on par with the aluminum version? How many polymer based lights have you personally known to have had a failure due to a durability issue? Plus, I'd take polymer body durability over all these "special metal" body runs. Much lighter to carry, except maybe versus the titanium version, but there's no logical way a polymer bodied HDS light would cost over $1000.
Or
The Polymer light is created in the same way like the i.e. the Surefire G2 is made. You have some metal parts that will be placed in a mold and the liquid polimer will be pressed into the mold. But I think making this molds is extremely expensive. More expensive than making a unique (only one unique) HDS light with a metal of your choice.
But the idea with the polymer HDS is still interesting.
Guess this is an issue. The metal body is used as a contact between head and battery. The wire contact is the signal contact to the rotary button or button if it is a clicky.I think HDS uses a little channel with a wire for contact. Shouldn't be an issue.
It is the same with the old Novatacs. This spring was used as 2nd contact for signaling on-off.
If the body is a polymer than a conductor is needed to replace the metal body. The wird you pictured is also needed. To replace the conductor that is the metal body the idea was using a metal sleeve like it is in the Surefire Nitrolon lights.
That is always good having one high quality light for a more affordable price in the product lineup. I could imagin with a polymer light this may be possible.Here's to keeping the new customer attracting, lighter, innovational, and non-$256/$1000+ HDS dream light alive!!
That is cool. It could also possible doing different colors of light without extra cost. If i.e. The green ones are sold out the next bat h is blue.... Blue? No yellowI know doing a mold with metal internals is ungodly expensive as I knew the guy who was producing the X7 (Kaiser) rifle. Jaw dropping expensive.
