Hexbright Flex
I know there are already are (have been?) some threads about Hexbright, but they are pretty wild and have been closing and opening for various reasons, so I'd like to start a clean one with a clear purpose. Without discussing the marketing of the light, I'll just say that for the next few days we have the opportunity to preorder it for a discount off of retail, and I'm sure I'm not the only one who'd like to make an informed decision about the light.
I want to talk about the merits of the
light based on what we
know about it (or what we don't know and could ask the designer about).
For example: It uses an XM-L and has a high of 500 lumens, so what would the runtime on high be like, and how long might we safely run it at that level? Or, what might be some advantages/disadvantages of it being programmable and rechargeable by it's micro usb hidden in the tailcap? What might be some useful ways to program the light (based on our understanding of the ways that it will be able to be programmed)?
I
do not want to talk about features we might like a light like this to have (I want it to have an RGB mode so I can take it to a rave! I want it to have 16gb of memory so I can use it as a flash drive! I want it to morph into an autobot!). This should help keep the thread on track about the Hexbright Flex as it is available to us.
I also
do not want to talk about the marketing of the light. This should help keep the thread from getting closed.
Here are the specs we have:
Hexbright Flex
Length: 5.25 in
Bezel Diameter: 1.125 in
Weight: 4.75 ounces
Max Output: 500 lumens
Amps at Max: 1.6 amp
Default Modes: h/m/l/flash
Battery: 1x18650 li-ion
USB Programmable
USB Rechargeable
(taken from
http://www.kickstarter.com/projects/527051507/hexbright-an-open-source-light)
Also from various parts of that site:
-it will be waterproof
-black, red, green, and blue anodizing available
-most likely programmable using an interface included or using C++, with backup default program in case you mess something up
-programmable by Mac, PC, or Linux
-lanyard hole
-60 minutes estimated at 500 lumens
-XM-L T6 1C, 6500K
-picture looks like it can tailstand?
If anyone has any other information about the light that you have found on that site or another, or from contact with the designers, feel free to add it here!
So, what do you guys think of this light? How might it compare to similar lights?
