Hi Vinh
So how does this compare with the one I got from you at the end of last year?
What did you get from me last year? I cant even remember things last week.
Hi Vinh
Sorry - M25C2vnT kit - single mode version. You said at the time that:
Yours will be a bit higher than below:
Eagle Tac M25C2vn KT XML2-U3 PDT Samsung 20r 11260 turn on 1130@ 30 sec 419 mid 61 low 265,000 lux
Eagle Tac M25C2vnT XPG2 PDT Samsung 20r 8160 turn on 783@ 30 sec 343,000 lux
So how does what you mention above as having the pencil beam compare with what I have for throw?
Ta
The larger one throws more with a smaller hot spot.
Can you guesstimate how much more?
Ummm wild guess but may be twice the size. I have not compared side by side.
$275 XPG2 PDTc = most throw but least output
$275 U3 PDTc = Medium Throw and output
$290 MTG2 = Least throw but highest output
+$5 if you want "V54" engraving
How much difference is between 1 and 2? Is it worth the lumen loss to go XPG2? I don't need measurements but a honest observation would be very useful. Thanks Vinh!
The xml2 is a laser. Xpg2 would be for specialized use only like an aspheric type beam I'm thinking
I own the xpg2 dedome version of the m25c2vn normal head version and it has such a focused beam its hardly usefull under 400 feet. hotspot might be bright but its so small it wont light up enough of what your trying to look at. its beyond a pencil beam imo. In this turbo head verison i think its only usefull if you want a flashlight laser. Xml2 might not throw as far but they are so close and the xml2 is much brighter the xml2 version will apper more inpressive. Im not saying i dont like it i love mine but i use it to point out stars lol. I think this turbo head version with dedome xpg2 could be the most focused most narrow beam ever seen from an led flashlight. Fun as a novelty but not much practical use.
