The
Cliff notes version of Unlocking the Programming on a Novatac 120T (or any other non 120P)
Drink Rum (optional but recommended).
1. Turn on the light,
then do 250+ clicks until the light starts flashing,
then hold for one second and stop clicking.
The light will be flashing once per second, this is Option menu 1
2. Click slowly 8 times, which gets you to Option 9,
(the light shows a dim to bright sequence but that does NOT mean the setting is enabled, do NOT Click)
3. HOLD the button down until the light turns off (light turns back on when you release the button)
4. Click off.
Your light is now programmable, pat yourself on the back and drink more Rum.
hints on how to more easily do the 250 click (no need to count)
Turn on light head down on a table, in a dark enough room so you can see the light coming out from the bezel scallops. Press button repeatedly without pause, with index finger, (the light stays ON)
keep clicking until the light starts flashing
it is not necessary to count to 250 and it is not necessary to hold-release the button after the 250 clicks, once you pass 250 instead of the light staying ON, it will be flashing, even if you keep clicking, it keeps flashing)
Next test your ability to
Program Brightness, levels of individual presets.
This includes turning Tactical STROBE OFF or on, also turning bicycle flasher on or off, and also SOS. These blinkies are reached the say way brightness is changed, just keep holding the button past the brightness setting and you get to the blinkies.
1. Turn the light on to whatever preset you want to modify.
2. Do double click HOLD.
Do NOT let go of the button, you MUST HOLD. The light will then step up in brightness while you HOLD the button.
3. When you let go of the button, the light stays on at the new level.
4. Click off, this saves the new brightness setting.
Note this is not the same as modern HDS, where advancing brightness levels requires clicking. With Novatac, HOLD is your friend for selecting brightness, and Hold is also your friend for enabling Option 9.
Hint, if you want to ramp down in brightness, at step 2 of ramping instructions, let go of the button, but DO NOT CLICK. Do double click hold, and keep holding as the light ramps down, then release at desired level, and click off to save.
Customizing the Options Menu
example turning on Last Mode Memory (turns off Force Preset), option 4:
1. Triple click hold release, the light will be flashing on Option 1
2. click 3 times slowly to reach Option 4
3. Press and HOLD until the light turns off (light turns on again when you release the button, this is normal)
4. Click off.
your light now turns on in the last mode used, pat yourself on the back again, and drink more Rum
here is a cheat sheet for all the operation inputs, and what each of the 9 Options Menu choices do:
Lastly, for now, here is a list of
programming presets for a 120T and what to change to make it into a 120P:
stock 120 T configuration:
click = 120 (maximum) lumens
double click = 10 lumens
tripple click = .33
from ON, press = Strobe
from OFF, press = maximum lumens (press uses the Primary mode and momentary)
from OFF, click press = Momentary Strobe
from ON, click press release = Strobe
Momentary, mode 7, ON
Ramping, Mode9, OFF
stock 120 P Presets
click = 11 lumens (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
double click = 30 lumens (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
tripple click = .33 (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
from ON, press = 120 maximum (this is set from click press from on, then double clic hold rising ramp until maximum, indicated by double flash. release at desired level, click turn off.. press level is saved)
from OFF, press = 11 lumens (this is set by Primary mode)
click press = maximum (set by using double click hold, to ramp up, cycles through strobe and SOS and minimum)
Momentary, mode 7, OFF (triple click hold to get to the 9 step option menu, release, click 6 times, hold till light turns off to toggle setting)
Ramping, Mode9, ON (triple click hold to get to the 9 step option menu, release, click 6 times, hold till light turns off to toggle setting)
