NaturalMystic said:
Hi, not to go off topic but I'm looking for a AA LED flashlight and have been looking at the Fenix line (considering the L1P & L2P special at Fenix-store.com) or the Inova X1. Can anyone familiar with both the X1 and L1P give their opinions, Pros & Cons of each, size comparisions, throw, etc??
Much appreciated.
NaturalMystic, I have two Fenix L1P and one of the new X1 with reflector. The L1P are much brighter, have a far greater throw, good white tint, and a bit over 2 hours run time from a 2500 NiMH. Add to this that they are waterproof, have a tail clickie, and can stand in candle mode. I picked up both of mine for less than $31 from 4sevens special offer.
The X1 is a little longer than the L1P, but a bit thinner. It is a close range/indoor light with a bluish cast to the beam. It has a twist switch, nice fit and finish with roughly 8 hours of runtime.
If you are going to use the light outdoors, or need something fairly bright, spring for the L1P. If you are going for long runtime and generally using the light indoors the X1 may fit your needs.
