Here's the exchange. It gives my impressions of the light.
Default Re: WTS: TNC Micro-Lux DragonQuote Originally Posted by djans1397 View Post
UGH! So tempting! I love my AAA's and this is def one of the more impressive ones I've seen. Is this a direct drive on turbo? With the wider head than body, how does it carry it pocket?
"It doesn't feel overly bulky in the pocket in my mokume version which is a bit heavier than the steel. The wider throw head doesn't feel too bulky either and the bigger reflector puts out a lot more light. I also believe the 1000 lumens setting is direct drive. I only run it for short periods on high, but it's amazing to see that in such a small light. I'd love a smooth, non-dragon body version too to show off the grain of the mokume better, but after querying TnC that isn't in the offing. The dragon body makes it a very tactile light, and often when I'm doing something mindless like watching TV, I find I take it out of my pocket just to fondle it. It might be my favorite AAA/10440 size light, and I have a lot of them (almost 70 at last count). It is definitely one of the most impressive AAA/10440 format lights out there. The only other AAA/10440 lights that I know of that are high end enough to compete with it are the MBI HF-R and Tain Ottavino (the AAA version, not the 10280), and the LiteFlux, but they're not nearly as bright."
As far as run times goes, I don't use it on high much and recharge the 10440 batteries often, so I've never run one down. But if you're going to use it on the higher settings I'd keep extra batteries with you as I doubt they would last long.
