RC40vn670 - RC40vn40 - X65vn2870 - TK75vn1670 - TK75vn Ideal - TK61vn Ideal
ven
Manchester UK
Re: RC40vn670 - RC40vn40 - X65vn2470 - TK75vn1670
Not sure on lowest limit NL, 4 lights is 80%+ so 1 light is 20% up to near 40% which would be 2 lights. When i have measured fully charged i am getting around 8.14 from memory which is around 90% charged. Good in ways as less stress on the cells over time..............
Newlumen
United States
ok -
fully charged 8.36V -
fully discharged 5.70v (the driver kept dropping into lower output levels)
I didn't test below 5.70v
Thanks.. I can calculate the runtime based on the 5.7v discharge.
Newlumen
United States
I run the 3 minutes straight at 70 percent which is translate to 28,000 lumen for rc40vn40. It did well. The light is warm to medium hot after 3 minutes. Great heatsink!. i conclude i can get 15 minutes runtime before the battery pack reach 6.0v.. ( 70% mode )...
just an estimate.. @ 8000 lumen, the runtime will be 52 minutes.
Los Angeles, CA
Hey Ven, do you know the working voltage for the rc40vn battery pack??? Example X65VN battery pack is 12 - 16.8.
I am exceedingly excited to receive my TK75vnQ70 package from Vinh and literally this blows away anything stock out there. I had a nightmare because I was looking at the stock Nitecore EA81 and psychologically stock flashlights are associated with my old toxic workplace environment. Vinh's custom flashlights are literally restoring my sanity.
i recall the Fenix RC40's mAh of its battery to be higher, and impressed me more than Acebeam's X65. I hope this feedback helps you a little bit, NL. I am impressed by RC40's 7,800mAh versus 6,400mAh with X65! 👨
ven
Manchester UK
They are different packs S&R, set up different (series/parallel inside along with 6 and 8 cells) for different LED voltages. The rc40vn40 is on vtc5 cells, these are 2600mah. The standard rc40 is fed on 2600mah sanyo cells, so 2s3p(iirc) would give you 8.4v and 3p which is 3x 2600mah=7800mah...............if makes sense. The x65vn has 3400mah cells , 4x4.2v so 4s=16.8v then 2p= 3400mah+3400mah = 6800 4s2p i presume the set up for the acebeam.
ven
Manchester UK
Its arrived!! How are you finding it S&R,a crazy wall of light!
Los Angeles, CA
For sure, works great. I call it a high output flooder. Power flooder and long reach. Definitely brighter than stock X65 without the washout blue tint that otherwise ruined it. Error-free UI. I accidentally knocked it flying to the ground from my bed table with my pillow and it is perfectly fine. This is like the dream Surefire M6-CB in LED. Yes Surefire M6-CB in LED! Vinh finally invented it!!👨
Newlumen
United States
I have tk75vnq70 diffuse dome. I like it better than tn36utvn or m43vn, because 17k lumen is damn bright and I can use extended runtime kit...
