Alaric Darconville
I went out this morning to find which wire on the headlight plug is power and considering it's ground switched I expected to get 12 V on the multi meter when I found it. I hooked the ground lead to the negative battery post and probed the two connectors in the plug. I got no voltage in both. With the high beam switch on, I get the 12 V on the power lead for the connector and 24.3 mV on the ground for the connector. This was all unplugged from the bulb.
I believe on my Previa the H4's "neutral" pole is the one that gets the power, the "hots" for each individual filament are the ones that are the ground and their path to ground is switched. So try putting the a probe on the "neutral" and on the negative battery terminal. It's also possible that your headlamp circuit is supervised and if filament resistance isn't detected, it may cut the power.
