Sky Lumen Delta PRE-ORDER
Newlumen
United States
Ok. Sorry for my poor English.. what I am trying to explain is thrunite button top is struck with the spring.. it's not a big deal and I could just pull it my hand... this light have double spring..
i avoid this issue by using acebeam..
Newlumen
United States
so if we can't use neither, which one can we use?
Vinh mentioned only to use protected 26650.. you can use like acebeam 26650, or keeppower 26650...
you can still use thrunite 26650, but the button top is struck with the spring and you will have to pull it out.. it will be fine if you use built in charging unit..
aginthelaw
NJ, USA
forgive me newlumen. i'm just picking on you because i'm jealous (you always get first crack at vinh's stuff). i appreciate the answer. i can see how the spring gets stuck. is this true with all the u21vn's? i've never had that problem with the other 4 (yes, i have more than one of these...it's a sickness you know)
Newlumen
United States
I have two u21vn.. it only happend to my last one.. maybe its just my light.. againthelaw, dont worry about it too much.. since you got many 26650 battery, it will be fine.
SKV89
Nice can't wait to play with it! Is the mirror finished reflector the reason this is better than the original U21vn?
SKV89
I paypaled you a few weeks ago but I dont see my username in the OP. Judt double checking you didnt miss me because I paypal as friend and family
Newlumen
United States
Manker is discontinuing the Manker U21. They do have some stock left for me. These will be re-branded with my simple Sky Lumen Logo and the name Delta.
Current U21vn SST40 HD/SD version are $150 and $200 for the Oslon Black version. I will do a short run of these at a discount for those interested on CPF only :). Prices will go up after this run.
All spec will have DriverVNX2 & USB charging feature retained. Oslon performance is phenomenal in this light! 800 Lumen and 465Kcd is crazy for this size. Minimal heat to manage. No numbers for SST40 but I expect the SST40 HD version to put out ~2000 Lumen and close to 200Kcd. SST40 SD gives relatively more throw and less output. Can't go wrong with SST40 or Oslon versions. Either will give best performance for this size. Artifacts free beams with any specs.
Delta Spec 1: You pick SST40 SD 6500K or HD 7500K $108
Delta Spec 2: Olson Flat Black 6500K $138
I will take 20 orders. Thanks for your support :)
Paypal: [email protected]
FREE SHIPPING USA
$20 International Shipping
1. eekazum Oslon
2. scout24 Oslon 1C
3. BF 40HD V54
4. Newlumen 40SD
5. IJK OSlon V54
6. bjs55 Oslon
7. LB Oslon V54
8. noboneshotdog Oslon V54 2C
9. rejsr Oslon V54 1C
10. LV_2 40HD
11. DHarp Oslon V54
12. Weazel132 Oslon V54 2C
13. Kevin1322 40SD
14. johnrseay Oslon V54
15. LB Oslon V54
16. LB 40HD V54
17. X-ray Oslon V54 1C
18. Icehole Oslon 1C
19. Thundertree 40HD V54
20. Bronco Oslon 2C
21. jkevind11 Oslon
22. Jose Marin Oslon
23. Disneyman26 Oslon V54 2C
24. Aginthelaw 40HD SPEC
#4. Olson black for newlumen..
SKV89
Are these going to be glued? Can I request the threads not glued because I just bought 2 wavien collars so I want to see if it fits in this light?
Skylumen
Building the first 8 Delta. Then I realized they forgot to send me E switch and contact board. This will cause a delay as I am emailing them for it now...Sorry all.
