precisionworks
The tail threads are "standard" C threads, identical to 6P, C2, etc. Head size & threading are unique to the X-series lights.
Just wondering what will be the output and runtime on 2x18650. I'm really tired low capacity K2 energy rechargeables.
Some P3X owners want to run a pair of 18500's & that's easily done after the bore is opened up to the larger diameter. A few owners want to run 2x18650 and that requires a bit more work:
The reason for the short spacer is that 2x18650 will not allow the tailcap to seat & the light will not work unless the TC is firmly seated. View attachment 1491View attachment 1492Here's the process for making the spacer:A 1" diameter brass bar is faced off, center drilled & starter drilled:View attachment 1493View attachment 1494View attachment 1495
- Add a one cell extender
- Add a short spacer
Hey first of all a belated thanks for the graph. But the problem is that I still cannot figure out a reasonable logic behind adding a spacer, whereas you could have added the extra length provided by the spacer to the extension tube itself. As per my elementary understanding the seating problem would occur due to insufficient length, if so then why bother adding a spacer rather making the extension tube appropriately taller.Some P3X owners want to run a pair of 18500's & that's easily done after the bore is opened up to the larger diameter. A few owners want to run 2x18650 and that requires a bit more work:
... then why bother adding a spacer rather making the extension tube appropriately taller.
+1... if you are in dot mil and going on a mission, are you going to drag a pile of 18mm Li-Ion cells with you, *and* back? No, lightweight primaries 123 rule in that case. Use them and discard them.
As far as I know the only option for High output first is the single output version (tactical model, P3XT-A). It also has High output second & third :devil:I would like the P3X to come on in HIGH first ...
Too bad... Have to look elsewhere, outside SureFire. Thank you!!As far as I know the only option for High output first is the single output version (tactical model, P3XT-A). It also has High output second & third :devil:
Reversing the levels would require a revision of the firmware. If the demand was great SF would offer this but I'm guessing that they have few requests from their primary buyers (MIL, LEO, etc.).
It is possible to use pair of 16670 with EXCAP in unbored P3X (7.4V, 2500mAh)why bother adding a spacer rather making the extension tube appropriately taller.
It is possible to use pair of 18650 with EXCAP in bored out P3X (7.4V, 3500mAh)some P3X owners want to run a pair of 18500's
I played with 18500 for a long time, never really satisifed. the problem is that the format is kind of abandoned by the manufacturers and is not developed like the 18650 format. The former is still stuck in the 1500 mAh land while 18650 is easily double that.
On my 2rd Gen P3X and also P2X the head is not glued. Therefore I can easy remove the head.Does anyone know how easily or not the heads come off the latest version of the P3X?
Nice find. Cant wait to see the light is everywhere available. I like the Intellibeam.Surefire now have the P3X Fury with IntelliBeam listed on their site.
