thermal guy
Well from now on I'll send you my lights for a photo shoot. Lol but I'll want them back.
Unfortunately I sold mine (previous gen to current) I must have been in a hurry and missed it.
More details...actual voltage of cells, was the module fresh off the shelf or already being used. It shouldn't be that far off. I notice once a light warms up, the readings can be different. Are the cells fresh? It only takes a second for the readings to drastically change when using cells. using primaries with 6.xx volts only takes a few seconds to be below 6 volts; resulting in skewed results. This is a reason why power supplies should be used for current draw readings. I don't have a good answer for you. Seems that the voltages are not what you think they are.
I am wondering if the info on the site is accurate? It shows both M61/M61N 800ma@6v but M61W@650ma. I would think the W is less efficient but I could be wrong. I know with the M61/M61N it doesn't take much to go from lower draw to an amp or better. This is where I can see the big increase you are seeing, but i don't know all the details. They do still seem a little high, but you have current gen where mine are before the driver update; so your readings sound in line for other voltages. If you are thinking you are reading 6v but aren't; thats where it makes sense to me. Anyway...
That's interesting because i show higher draw on li-ion 4.15-4.2v than 6v on pretty much all modules.They were fresh 123's. Starting volt on both 3.2.Got 1 A steady. What's strange is I'm getting 1.2 amps with a Lithium ion at 4.2. None of my other Malkoff pull more from a 18650 then they do with two primaries.
Nice:thumbsup:She's got a Malkoff M91 and tricap so I think it's ok to post in this thread
