The MOSFET carries ALL the current and has a tiny fraction of the resistance of even a modified Magswitch. The Mag switch itself just controls the MOSFET with a nanoAmp or 2.
The MOSFETs I'm using are N-FETs (N-Channel MOSFET), they turn ON when you apply a (+) voltage and OFF when you apply a (-) or zero voltage.
The PMOS or P-FET (P-Channel MOSFET) operates just the opposite. (+) for off (-) for ON. But due to their semiconductor design they have higher resistance.
A CMOS is a design method for semiconductor chips.
The soft-start circuitry just controls the MOSFETs on or off state a lot faster than you can with the Magswitch. Other than that, the MOSFET itself is wired the same.
OK, so then does the stock magswitch get connected only to a circuit with 2 contact points on the mofset, and then the main Pos/Neg battery & bipin leads have another set of separate contact points on the mofset?
