I had established this multiplier for my DIY rig from previous testing and used it to test the lights. The results are as follows;
- M91T on two cells = 780 lumens (rated at 750 lumens)
- M61HOT v.2 on one or two cells = 635 lumens (rated at 740 lumens)
- M61SHO on one or two cells = 570 lumens (rated at 825 lumens)
- M91B on one cell = 450 lumens (no single cell rating)
- M61T on two cells = 425 lumens (rated at 425 lumens)
The important consideration is not the calculated output (which has plenty of potential error), but the
comparative output of each module (which has little potential error).
The M91T and M61T are pretty much on target with their ratings. This has generally been the case with all Malkoff lights I've tested in the past.
My sample of the M91B has always been a dog - there's no way it hits the rated 1,000 lumens no matter how many cells it's run on. On four CR123 batteries, the Bodyguard v.2 on a single Li-ion cell still blows it away.
My sample of the new M61HOT v.2 does not reach its 740 lumen rating. Even if I use 900 lumens for the M91T to calculate the multiplier, the M61HOT gets to 730 lumens. I'm inclined to give it a pass due to the potential error in my measuring process.
My sample of the M61SHO was not even close to its rated output, and even any error in my process does not account for it. This was no surprise as my Surefire E2T Tactician (rated at 800 lumens, measured in this testing at 804 lumens) is clearly more powerful by simple observation. According to my measurements and observations, the M61SHO does not match the M61HOT v.2 in either lumens or candela.
Observations - M61HOT v.2 vs. M91T
I had always assumed based on their ratings that the M61HOT and M91T were essentially identical in output. At least with my samples, this appears
not to be the case;
- The M91T has greater output (measured and observed)
- The M91T has a substantially tighter and brighter hot spot, and substantially higher observable candela
- The M61HOT v.2 is noticeably cooler in color temperature
- The M61HOT v.2 has a MUCH more uniform beam pattern and no "Donut of Darkness" surrounding the corona like the M91T
- The output of the M61HOT v.2 is rock solid vs. voltage: from 4.0 volts to 8.4, the lux reading remained the same
Conclusions
Even though the output does not match my sample of the M91T (and according to my measurements struggles to meet its rated output), the new M61HOT v.2 remains the top dog of the Malkoff M61 series. Though a bit cooler than I care for, and the noticeable square corona caused by the TIR optic projecting the shape of the emitter, the overall beam is more uniform with brighter spill compared to my sample of the M91T. With the high/low switch installed, the low setting is perfect for night adapted vision inside the house.
As planned it has been installed on my night stand light where it provides a better-than-expected upgrade over my M91B running on a single Li-ion cell.
