WebHobbit
You're gonna have to post pics....beam shots too.
WebHobbit
head 22.3 is not listed on the site, but you may request that Cathy add in your order or replace model 16.5 with model 22.3.
In my last purchases I requested this replacement.
So what are you saying? You placed orders for the 16.5 as a part...and then emailed Cathy to swap in the 22.3? I think there is enough interest now that it needs to be added to the parts sales list! Gene are you reading this?
Anyone know the size of a spacer to fit a CR123 in an AA (wide enough so talking about length) body? ....
That looks great! Do you (or anyone else) have an MDC CR123 with standard MDC head that you could take a picture of them together? Would like to know which is longer and how much wider the VME head is? I'm still considering a single level CR123 MDC. Looks like with the cool versions its 250 lumen with standard head versus 280 with the M31 and VME. The standard MDC head lists 45-60 minutes for run-time. Is the VME M31 longer?
Without actually measuring anything ...
AA ~ 14500 size
(minus)
CR123 ~ 16340 size
(sorta equals)
~ 16 mm (?)
(and you already noted the difference in width)
I swapped the head o-ring with a larger diameter one to give extra resistance, put an extra o-ring on the tail end...
Yes, same reason I went to the T over the HOT. On an 18650 I got 3 hours of bright light. Taper from there. Plus it likes primaries and 16340s if one desired.I am also waiting for the arrival of a dropin m61t. I have a m61hot, but I think the m61t model has a better balance between power and consumption. in my research I found that it is much more powerful than the m60 model and with little difference in consumption. It's literally an upgrade. in the future I would like to have an m60 for collection purposes.
I struggled with this, but went with the HOT because I use my MD2 with standard M61 drop ins for lower output/longer run times. I doubt it's much brighter than the M61T, but I like the snappy beam.
