Okay, this is what i got with my initial testing of H/L ring on T/HOT
HOT:
3.2v from power supply: approx 3.9lm
4.2v from power supply: approx 8lm
6.0v from power supply: approx 16.7lm
4.15v from li-ion: approx 7.4lm
6.24v from 2x primary: approx 17.5lm
So it seems that in this particular case, the power supply and actual cell are closely matched
T:
3.2v from power supply: approx 1.1lm
4.2v from power supply: approx 5.6lm
6.0v from power supply: approx 14.5lm
4.15v from li-ion: approx 5.3lm
6.24v from 2x primary: approx 15.5lm
8.3v from 2x li-ion: approx 25.7lm
so again, power supply and actual cells are closely matched in this test
With all this being said: @ETC: what cells will you mostly be using for me to get the 40-50lm you are after from low mode? Being the T is versatile, this may be a trick. I can base it off of single li-ion which is what I think Malkoff does. then you will have to deal with what you get from other variations. Or i can set it based off 6v? I'm not sure.
This will be custom tailored to your wish
