fyrstormer
Banned
Actually, 18650s are starting to fall out of favor as laptop batteries, compared to folded Lithium Polymer batteries, because they can be made to fit into the entire underside of the laptop. Makes me wonder how much power could be gotten from a Li-Po battery coiled into the shape of an 18650.
Regarding the springs on McClicky switches: the first thing I do with every McClicky I buy, whether loose or installed in a light, is crush the spring flat. That shortens and softens it a little bit. I also sand down the tip of the spring in case the end of the spring coil has a sharp edge that might dig into my batteries. Doing both of these things has made using McClickies completely irritation-free.
One last thought regarding the design of the ROTOR tube: make the front part of the tube long enough for the user to hold securely while unscrewing the back part of the tube. Since the front part doesn't need to be unscrewed from the head in order to change the battery, the easiest (and cleanest) usage would be to leave the front part screwed into the head at all times, and unscrew the front part from the back part to change the battery. Maybe a bit of knurling or TB-style cut squares would be appropriate to improve grip while unscrewing the two parts of the tube from each other.
