Thanks, imma go out in a bit with some lights, will report back later.Congrats josh,certainly for its size , one of my most impressive
Vinh,
I will take a TM06vn U3 Dome On option.
Thanks
You will love it.
Sent from my iPhone using Candlepowerforums
Well im back now, its a good light, but theres hardly any difference between the last to modes, i was using the 18650BE cells.
If you want to see the difference between Turbo and high, take the light and set it for turbo, then turn the light off. Wait a few moments, then turn the light back on. Because of the memory it should start in turbo. Now using half clicks, click once. It should drop from turbo to high. You'll notice the difference.
As has been stated in other threads, the eyes are poor light meters.
Thanks, i tried what you said and its still close to the same brightness.Yes josh,as NoNotAgain says eyes are not the best light meters .From high to turbo is a slight bump,go from turbo and 1/2 press to high,you should notice the difference more going backwards . Well I can anyway :laughing:
Also don't forget the simple guide , it requires around 4x the lumens to appear twice as bright.
It doesntbotherme to much, its kindz like my TN12 2014 High and Turbo are almost the same, but i do wonder if the TN12 2014 will be brighter with UNprotected cells. Im happy with the TM06vn, im getting the TN36vn on Tuesday, and i just ordered the MM15vn, so now it will be fun to compare them.Some of Vinh's lights are just that way...when the current is boosted, it doesn't always boost each level proportionately. My Tk75vn and K40vn were/are like that too - high and turbo very close to one another.
If it really bothers you, might want to e-mail Vinh, see if anything can be done. To me it wasn't a big deal, but he wants you to be happy with it.
At 3.7v they won't be able to sustain turbo and will just run in high . As said ,my tk75vn is very close if not closer from high to turbo to me . Still the slight bump in power does make a difference further away in the dark. Your eyes would not be able to tell a few hundred lumens,so by noticing shows the bump is still a sufficient amount imo.
You will icertainly see a bump on the mm15vn :laughing: as its from a high of around 2000lm to 7400 OTF lm.
How do you find the tint/flood josh?
I am pretty blown away by the output of this tiny monster
Samsung INR18650-20R 2000mAh Button Top
These batteries are available at mtnelectronics.com
They show having 12 in stock at the moment.
Thanks flr that, are they a reliable seller?, i wonder if the 25R would make a difference.And Illumination Supply has the 25R, for less than the 20R at Mountain Electronics. I'll take 25% more capacity for a lower price, yes I will.
