Sold/Expired TNT SingLED modules for Surefire incan E-series
Tana
Bosnia & Herzegovina
How do you get 110 bulb lumens out of the MN01, which I believe is rated at 15 lumens when powered by 1xCR123A? That bulb draws about 0.7A, which is twice the output of 1x7135, so if anything you will be underdriving the lamp.
What I plan to do is... install Nichia219 LED on one of these pills which is going to be driven by one of NANJG ROHS-111 driver stripped of all but one 7135 regulator... it would be SINGLE MODE, of course... and at that amperage, the LED outputs about 114 lumens... Now, the choice of the battery would dictate whether we strip polarity protection diode from the driver also... by removing it, there will be no voltage drop that that diode is making and the LED would stay longer in regulation when powered with single CR123 primary battery... that's why I call this "direct replacement of MN01 bulb", because it's the closest you can get to it that I can think of... it's only CR123 friendly, Li-Ion would put too much voltage to the LED... it would probably work but would stress LED too much with constant use...
That way it would stay in that 80 OTF lumens range for couple of hours then start long and nice dimming... It should be 2-3 hours before unnoticeable dimming start... as for runtime, you get the idea... max pull is 350mA thanks to that single regulator... from 1400mAh battery, it's min of 4 hours of light... but it will be HOURS of running since as the voltage drops, the amp pull will be less than 350mA...
cland72
I have an E1E host just waiting for this to become a reality!
Tana
Yeah... Unless Justin proves my theory wrong... :)
Honestly... I don't understand why noone never tried making few this way... I'm sure lot of people would like something with single mode, bright enough (this is maybe even too bright) to replace their stock MN01 they use with E1E... I've seen so many people when deployed using E1E's as their EDC... module that would increase output and runtime by several-fold is just great for them, imho... Majority of them like to have it single mode, even if it was only 15 lumens... they only didn't like the runtime they had...
scsmith
I'm now glad I hesitated on the current run of N219 you're doing. I'm going to wait on this version to get worked out. If you think it could handle the 3.2v of a Lithium Iron Phosphate (LFP, LiFePo4) that would be awesome. 80 lumen OTF in a direct MN01 replacement with that kind of run time would be ideal. I'd really like to get that tiny little incan head back on my E1e.
Tana
Well then... I only had one of these single mode drivers (have 15 on order but it will be in the second part of May until they are here) that I prepared for your tower... didn't put it together as I suggested lower amp for it and was waiting for your answer... now I can strip that one and make first MN01 replacement SingLED and see how it performs...
P.S.
I seriously need to get a decent lux meter... nothing to give me EXACT lux numbers but to allow me to COMPARE with others that are set in stone (Malkoffs, Surefires, et cetera)...
EDIT:
Well, so much about "more lumens" theory in this setup... once the light is run in direct drive from CR123, it pulls 250mA @ 3.10V (brand new, fresh cell), 230mA @ 3.05V (little used cell) and 50mA from 2.93V cell... I'm comparing it to the original incal bulb and the incan seems to have slightly more intense hotspot but the LED has a lot lumens lost in spill... lighting the room much wider... it's just interesting to compare stock bulb with this direct driven Nichia219... the bulb makes a great contrast but it's incandescently orange... Nichia219 is picking up the colors just as easily but with way "cooler" light... daylight, to be precise...
So now I've left it running on a fresh cell and will see what runtimes it can make on one primary...
Tana
I'm sure it will function, but it probably won't pull the full 350mA drive.
The Nichia datasheet says Vf is typically 3.0V at 350mA drive. Doesn't say what Vf rank, so if you're lucky, your emitters have lower Vf. But if you need 3.0V for 350mA drive, you aren't going to get it from 1x123A. Referencing Silverfox's 123 shootout curves and extrapolating a bit, at 500mA current draw, a 123A cell can hold about 2.75V under load. Most likely, 350mA drive will give similar results. Also factor in that a 7135 needs another 120mV to reach full regulation and you need 3.12V min. That excludes parasitic resistance in your flashlight (from contact resistances, switch resistances, etc), that add additional voltage drop that needs to be overcome. If we assume 100milliohms parasitic resistance, then that gives another 0.035V, for an estimated total of about 3.15V. At that level, I'd say it is 99.99% certain that you won't reach full regulation.
However, the 7135 is a very forgiving chip. Even if you are at say 2.8V or something like that, you should get something close to full regulation. And you get that superlong tailoff wrt output. You don't get the sudden shutoff like you do with a buck driver. So tens of hours later, you will still get some lumens output.
If you want to run the Nichia in full regulation off of 1x123A at 350mA drive, my suggestion still stands -- use a 14mm diam Sandwich Shoppe GD boost-buck driver.
Yup... you've pretty much theoretically nailed it... these are my testings so far:
Start @ 0850 draw 230mA (battery has 3.05V)
@ 0855 draw is 170mA
@ 0905 draw is 140mA
@ 0920 draw is 135mA
@ 0940 draw is 125mA
@ 1000 draw is 125mA
@ 1110 draw is 125mA (battery shows 2.90V)
Made a break here... comparing to incan MN01 it still shows about the same lumen output, only less concentrated into hotspot but more into spill... now continuing again, initial startup draw is 170mA again but it dropped to 125mA and holding... like I said... it's direct replacement for MN01 bulb... with about 4x and more runtime...
I kind of like it like this... as for other drivers, I will look into implementing them but not for now...
EDIT:
Another three hours of runtime, from 16:45 until 19:45... the current draw went from 125mA to 110mA and battery voltage from 2.87V to 2.835V... it's still going "strong" but I got tired... so after 5 1/2 hours of running on primary cell, the output is still around 35 emitter lumens... still seems like the same output of MN01 with fresh cell with that catch - more lumens is lost in spill compared to brighter hotspot of MN01... I believe it would run the whole night...
Basically this setup is perfect for people who already have E1E and already use MN01 bulb... in case their bulb goes bad, this SingLED would be interesting for them as it can be both Nichia219 or Hi-Cri XPG which is even closer to their original setup... but then forget about ever swapping the battery...
Tana
OK... the single mode in direct drive SingLED showed to be half-impressive... impressive with runtime of 6-8 hours and not so impressive with 15-20 OTF lumens output... so this module is set aside and will get surgery - removing ROHS-111 driver and installing well proven 101-AK-A1 with 3-modes and 2.8-6V range...
However... sometime in the future I'll definitely make this single mode driver but will find one as a base that has BOOST regulation, then play with resistors to get to around 60 OTF lumens output and about 2-3 hours runtime... it might not be a close future...
But anyone interested in MN01 replacement, same output and 8x more runtime, I could build it quickly as per previous few posts...
Justin Case, thanks for jumping in here for theory support... I appreciate it...
Now back to assembly for hungry members...
hockeypuck08
Tana,
I've received the 3-mode XP-G2 module you sent. Good flood and a nice hotspot. Very happy with it.
My original intention was to use it with a E1L body which I had been EDCing. To my surprise the dropin didn't fit! The pill wouldn't go all the way into the tube so I can't screw the bezel on. However, it does fit perfectly on a E1E/E2E body. So I guess the E1L has a smaller diameter tube, never knew that, I assumed they would be the same.
Nonetheless I'm very happy with the dropin. Thank you for offering a great product.
Tana
Tana,
I keep the lower diameter of them at 17.10mm for few reasons... one is to give that extra thickness to the walls and second is for better thermal transfer... if you want to use it with E1L body, you could just sand that part around until it fits E1L body (with 1000 grip sandpaper or something)...
Surefire has slight variations between runs and generations of their E series... early bodies (that fit 17670 cells by default) have internal diameter at 17.20mm... I tried my first 10 or so SingLEDs on my E1E-BK body, E1e-HA body but few days ago I got E1e-BK body and I've noticed the same thing... like you just said, it's not a big deal, few moves with fine sand-paper can fix the fitment and keep it to tight fit for better thermal transfer...
I'm glad you like it...
kongfuchicken
Santa Cruz, CA
I just got the 219 module and I'm super happy with it.
The 3 drive levels are well balanced and work great with the e2 reflector.
I look forward to playing with it more after the sun sets...
Redhat703
Can you guys provide a beam shot of the 219 3-mode module. I'm interested in one for my SF E2D. Has anyone tried this module with li-ion 17670, and what was the run time?
Thanks,
Tana
Thanks,
Redhat703,
Sorry, I'm stuck in the middle of nowhere on this ultra-quiet pre-season vacation with my wife... as soon as I get home, I'll have to do TONS of beamshots (I suck in making them but I do need to make few for pretty much any product I have) and post to appropriate threads... Unless someone with more experience beat me to it who already have my SingLED...
It's pretty much the same beam as with any other E-tower made in the past by any modder... except that Nichia gives great tint even in this shallow and wide reflector...
Tana
I was asked by a fellow member who is getting my TripLED service to put an affordable P60 module for him... He wished for four-color MC-E so I thought - why not... since we already have waiting time for bezel to get to me, I ordered the LED and driver along with P60 pill and reflector...
I do not plan to concentrate a lot on doing P60's but if anyone is interested, any type (XPG2, XML2, 219, XPE2, MC-E/WRGB), let me know and we can put it together parallely to main project - SingLED and TripLED... I'll let you know the expenses in PM as it's not my primary interest right now, rather a reach to help fellow member but I promise it to be affordable... it would ship together with SingLED or TripLED, depending on your primary interest... :thumbsup:
RGB_LED
North of 43
Thanks,
I just received my XP-G2 version and it's a great little dropin. As Tana said, the beam is similar to others like it, fairly narrow hotspot and wide spill due to the stock reflector. I would take a beamshot but it's not the Nichia 219 version so don't think that would help. The XP-G2 version is also quite white and, as indicated by Tana to me, it doesn't have that yellow fringing. :thumbsup:
I also did a non-scientific runtime test with my SF E2 body, SingLED and a fairly old (2 yrs+) AW 17670 that had a starting voltage of 4.18v. It ran for 1:12 till the low voltage cutoff kicked-in, then the output dropped and began to blink every 2-3 seconds. Ending voltage was 3.24v.
Redhat703
Redhat703,
I also did a non-scientific runtime test with my SF E2 body, SingLED and a fairly old (2 yrs+) AW 17670 that had a starting voltage of 2.18v. It ran for 1:12 till the low voltage cutoff kicked-in, then the output dropped and began to blink every 2-3 seconds. Ending voltage was 3.24v.
Thanks you guys so much for your information! Very tempted :)
